Datasheet DP83620SQE/NOPB - National Semiconductor Даташит ИС, ETHERNET CONT, IEEE802.3, 100 Mbps, LLP-48 — Даташит
Наименование модели: DP83620SQE/NOPB
41 предложений от 17 поставщиков
Чип интерфейса, TEXAS INSTRUMENTS DP83620SQE/NOPB Ethernet Controller, 100Mbps, IEEE 802.3u, 3V, 3.6V, LLP, 48Pins
DP83620SQE/NOPB
от 94 ₽
DP83620SQE/NOPB
214 ₽
Эиком
DP83620SQE/NOPB
от 617 ₽
Hi-Tech Circuit Group
DP83620SQE/NOPB
Описание: ИС, ETHERNET CONT, IEEE802.3, 100 Mbps, LLP-48
data sheetСкачать Data Sheet
DP83620 Industrial Temperature Single Port 10/100 Mbps Ethernet Physical Layer Transceiver with Fiber Support (FX)
February 23, 2011
1.0 General Description
The DP83620 is a highly reliable, feature rich device suited for industrial applications.
The DP83620 offers low power consumption, including several intelligent power down states. In addition to low power, the DP83620 is optimized for cable length performance far exceeding IEEE specifications. The DP83620 includes a 25MHz clock out. This allows the application to be designed with a minimum of external parts, which in turn results in the lowest possible total cost of the solution. The DP83620 offers innovative diagnostic features unique to National Semiconductor, including dynamic monitoring of link quality during standard operation for fault prediction. These advanced features allow the system designer to implement
  • Скорость передачи данных: 100 Mbps
  • Number of Ports: 1
  • Ethernet Type: IEEE 802.3
  • Ток потребления: 105 мА
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: LLP
  • Количество выводов: 48
Дополнительные аксессуары:
  • SPC Technology - 4004
На английском языке: Datasheet DP83620SQE/NOPB - National Semiconductor IC, ETHERNET CONT, IEEE802.3, 100 Mbps, LLP-48
