Datasheet LM3528TME/NOPB - National Semiconductor Даташит — Даташит
Наименование модели: LM3528TME/NOPB
22 предложений от 14 поставщиков
Драйвер LED , TEXAS INSTRUMENTS LM3528TME/NOPB Led Driver, 2Outputs, Boost (Step Up), 2.5V-5.5V in, 1.27MHz switch, 20.6V/30mA out, SMD-12
Рутоника
LM3528TME/NOPB
109 ₽
LM3528TME/NOPB
145 ₽
LM3528TME/NOPB
от 371 ₽
LM3528TME/NOPB
data sheetСкачать Data Sheet
LM3528 High Efficiency, Multi Display LED Driver with 128 Exponential Dimming Steps and Integrated OLED Power Supply in micro SMD
August 3, 2008
LM3528 High Efficiency, Multi Display LED Driver with 128 Exponential Dimming Steps and Integrated OLED Power Supply in a 1.2mm Ч 1.6mm µSMD Package
General Description
The LM3528 current mode boost converter offers two separate outputs.
The first output (MAIN) is a constant current sink for driving series white LED's. The second output (SUB/FB) is configurable as a constant current sink for series white LED bias, or as a feedback pin to set a constant output voltage for powering OLED panels. As a dual output white LED bias supply, the LM3528 adaptively regulates the supply voltage of the LED strings to maximize efficiency and insure the current sinks remain in regulation. The maximum current per output is set via a single external low power resistor. An I2C compatible interface allows for independent adjustment of the LED current in either
  • Topology: Boost (Step Up)
  • Количество выходов: 2
  • Выходной ток: 30 мА
  • Выходное напряжение: 20.6 В
  • Диапазон входных напряжений: 2.5 В ... 5.5 В
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Switching Frequency: 1.27 МГц
  • Efficiency: 90%
  • Влагостойкость: MSL 1 - Unlimited
На английском языке: Datasheet LM3528TME/NOPB - National Semiconductor
