Datasheet LP5523TM/NOPB - National Semiconductor Даташит — Даташит
Наименование модели: LP5523TM/NOPB
20 предложений от 14 поставщиков
Драйвер LED , 9Channel RGB/White LED driver with Internal Program Memory and Integrated Charge Pump - DSBGA 25-DSBGA -30 to 85...
LP5523TM/NOPB
от 45 ₽
LP5523TM/NOPB
95 ₽
Hi-Tech Circuit Group
LP5523TM/NOPB
LP5523TM/NOPB
data sheetСкачать Data Sheet
LP5523 PRODUCT BRIEF
December 16, 2009
LP5523 PRODUCT BRIEF Programmable 9-Output LED Driver
General Description
The LP5523 is a 9-channel LED driver designed to produce lighting effects for mobile devices.
A high-efficiency charge pump enables LED driving over full Li-Ion battery voltage range. The device is equipped with an internal program memory, which allows operation without processor control. The LP5523 maintains excellent efficiency over a wide operating range by autonomously selecting the best charge pump gain based on LED forward voltage requirements. LP5523 is able to automatically enter power-save mode when LED outputs are not active, thus lowering idle current consumption down to 10 µA (typ). The LP5523 has an I2C-compatible control interface with four pin selectable addresses. The device has a flexible General Purpose Output (GPO), which can be used as a digital control pin for other devices. INT pin can be used to notify processor when a lighting sequence has ended (in
  • Topology: Charge Pump
  • Количество выходов: 9
  • Efficiency: 93%
  • Влагостойкость: MSL 1 - Unlimited
  • Peak Reflow Compatible (260 C): Yes
  • Pb-Free: Yes
На английском языке: Datasheet LP5523TM/NOPB - National Semiconductor
