Datasheet LT1963AES8 - Linear Technology Даташит ИС, ADJ LDO REG 1.21 В TO 20 В 1.5 А 8-SOIC — Даташит
Linear Technology LT1963AES8
Наименование модели: LT1963AES8
45 предложений от 29 поставщиков
Чип стабилизации напряжения, LINEAR TECHNOLOGY LT1963AES8-2.5#PBF Fixed LDO Voltage Regulator, 2.1V to 20V, 340mV Dropout, 2.5Vout, 1.5Aout, SOIC-8
Рутоника
LT1963AES8-1.5#TRPBF
220 ₽
Зенер
Россия и страны ТС
LT1963AES8-1.5#PBF
от 263 ₽
SUV System
LT1963AES8-3.3#PBF
Hi-Tech Circuit Group
LT1963AES8-3.3
Производитель: Linear Technology
Описание: ИС, ADJ LDO REG 1.21 В TO 20 В 1.5 А 8-SOIC
data sheetСкачать Data Sheet
LT1963A Series 1.5A, Low Noise, Fast Transient Response LDO Regulators FEATURES
n n n n n n n n n n n n n n n n
DESCRIPTION
The LT ®1963A series are low dropout regulators optimized for fast transient response.
The devices are capable of supplying 1.5A of output current with a dropout voltage of 340mV. Operating quiescent current is 1mA, dropping to < 1A in shutdown. Quiescent current is well controlled; it does not rise in dropout as it does with many other regulators. In addition to fast transient response, the LT1963A regulators have very low output noise which makes them ideal for sensitive RF supply applications. Output voltage range is from 1.21V to 20V. The LT1963A regulators are stable with output capacitors as low as 10F. Internal protection circuitry includes reverse battery protection, current limiting, thermal limiting and reverse current protection. The devices are available in fixed output voltages of 1.5V, 1.8V, 2.5V, 3.3V and as an adjustable device with a 1.21V refere
  • Входное напряжение минимальное: 20 В
  • Output Voltage Adjustable Range: 1.21 В ... 20 В
  • Dropout Voltage Vdo: 340 мВ
  • Количество выводов: 8
  • Выходной ток: 1.5 А
  • Рабочий диапазон температрур: -40°C ... +125°C
На английском языке: Datasheet LT1963AES8 - Linear Technology IC, ADJ LDO REG 1.21 V TO 20 V 1.5 A 8-SOIC
