Datasheet LTC2871IFE - Linear Technology Даташит — Даташит
Наименование модели: LTC2871IFE
32 предложений от 18 поставщиков
IC TRANSCEIVER FULL 3/3 38TSSOP. 3/3 Transceiver Full Multiprotocol 38-TSSOP-EP. Interface - Drivers, Receivers, Transceivers
LTC2871IFE#PBF
723 ₽
LTC2871IFE#PBF
1 449 ₽
LTC2871IFE TRPBF
Hi-Tech Circuit Group
LTC2871IFE#TRPBF
Производитель: Linear Technology
data sheetСкачать Data Sheet
FEATURES
n n n n n n n n n n n
LTC2870/LTC2871 RS232/RS485 Multiprotocol Transceivers with Integrated Termination DESCRIPTION
The LTC®2870/LTC2871 are robust pin-configurable multiprotocol transceivers, supporting RS232, RS485, and RS422 protocols, operating on a single 3V to 5.5V supply.
The LTC2870 can be configured as two RS232 single-ended transceivers or one RS485 differential transceiver on shared I/O lines. The LTC2871 offers independent control of two RS232 transceivers and one RS485 transceiver, each on dedicated I/O lines. Pin-controlled integrated termination resistors allow for easy interface reconfiguration, eliminating external resistors and control relays. Half-duplex switches allow four-wire and two-wire RS485 configurations. Loopback mode steers the driver inputs to the receiver outputs for diagnostic self-test.The RS485 receivers support up to 256 nodes per bus, and feature full failsafe operation for floating, shorted or terminated inputs. An integrated DC/DC boost
  • Device Type: Transceiver
  • Количество драйверов: 2
  • Диапазон напряжения питания: 3 В ... 5.5 В
  • Тип корпуса: TSSOP
  • Количество выводов: 38
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Pb-Free: Yes
  • Peak Reflow Compatible (260 C): Yes
На английском языке: Datasheet LTC2871IFE - Linear Technology
