Datasheet LTC3675EUFF - Linear Technology Даташит ИС, PMIC, 1 А, QFN-44 — Даташит
Наименование модели: LTC3675EUFF
![]() 33 предложений от 18 поставщиков IC: PMIC; преобразователь DC/DC; Uвх: 2,7÷5,5ВDC; 2,8А; QFN44; Ch: 1 | |||
LTC3675EUFF#PBF Analog Devices | 385 ₽ | ||
LTC3675EUFF#PBF Analog Devices | от 1 291 ₽ | ||
LTC3675EUFF#PBF Analog Devices | от 1 415 ₽ | ||
LTC3675EUFF#PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, PMIC, 1 А, QFN-44
LTC3675 7-Channel Configurable High Power PMIC FEATURES
n n n n n n n n n n n n
DESCRIPTION
The LTC®3675 is a digitally programmable high efficiency multioutput power supply plus dual string LED driver IC optimized for high power single cell Li-Ion/Polymer applications.
The DC/DCs consist of four synchronous buck converters (1A/1A/500mA/500mA), one synchronous boost DC/DC (1A), and one buck-boost DC/DC (1A) all powered from a 2.7V to 5.5V input. The 40V LED driver can regulate up to 25mA of current through two LED strings with up to 10 LEDs each. The LED driver may also be configured as a general purpose high voltage boost converter. DC/DC enables, output voltages, switch slew rates and operating modes may all be independently programmed over I2C or used in standalone mode via simple I/O and power-up defaults. The buck DC/DCs may be used independently or paralleled to achieve higher output currents with a shared inductor. LED enable, 60dB brightness control and up/down gradation are p
- Напряжение питания: 5.5 В
- Number of Step-Down DC - DC Converters: 4
- Number of LDO Regulators: 1
- Тип корпуса: QFN
- Количество выводов: 44
- Number of Regulated Outputs: 7
- Рабочий диапазон температрур: -40°C ... +125°C
