Datasheet MAX11616EEE+ - Maxim Даташит ИС, ADC, 12 бит, 94.4 kSPS, QSOP-16 NW00 — Даташит
Maxim MAX11616EEE+
Наименование модели: MAX11616EEE+
46 предложений от 19 поставщиков
АЦП, низкой мощности, 12 бит, 94.4 Квыборок/с, Дифференциальный, Несимметричный, I2C, Однополярный
MAX11616EEE+
Maxim
от 1 257 ₽
MAX11616EEE+
Maxim
от 1 764 ₽
MAX11616EEE+
Hi-Tech Circuit Group
MAX11616EEE+
Производитель: Maxim
Описание: ИС, ADC, 12 бит, 94.4 kSPS, QSOP-16 NW00
data sheetСкачать Data Sheet
19-4561; Rev 3; 2/11
KIT ATION EVALU BLE AVAILA
Low-Power, 4-/8-/12-Channel, I2C, 12-Bit ADCs in Ultra-Small Packages
General Description
The MAX11612­MAX11617 low-power, 12-bit, multichannel analog-to-digital converters (ADCs) feature internal track/hold (T/H), voltage reference, clock, and an I2C-compatible 2-wire serial interface.
These devices operate from a single supply of 2.7V to 3.6V (MAX11613/MAX11615/MAX11617) or 4.5V to 5.5V (MAX11612/MAX11614/MAX11616) and require only 670µA at the maximum sampling rate of 94.4ksps. Supply current falls below 230µA for sampling rates under 46ksps. AutoShutdownTM powers down the devices between conversions, reducing supply current to less than 1µA at low throughput rates. The MAX11612/MAX11613 have 4 analog input channels each, the MAX11614/MAX11615 have 8 analog input channels each, while the MAX11616/MAX11617 have 12 analog input channels each. The fully differential analog inputs are software configurable for unipolar or bipolar, and si
На английском языке: Datasheet MAX11616EEE+ - Maxim IC, ADC, 12 bit, 94.4 kSPS, QSOP-16 NW00
