Datasheet MAX13488EESA+ - Maxim Даташит ИС, RS422/RS485 TRANSCEIVER — Даташит
Наименование модели: MAX13488EESA+
Купить MAX13488EESA+ на РадиоЛоцман.Цены — от 54 до 749 ₽57 предложений от 25 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| MAX13488EESA+T Maxim | 75 ₽ | ||
| MAX13488EESA+ Analog Devices | от 527 ₽ | ||
| MAX13488EESA+ Analog Devices | по запросу | ||
| MAX13488EESA+T Maxim | по запросу | ||
Производитель: Maxim
Описание: ИС, RS422/RS485 TRANSCEIVER
19-0740; Rev 0; 1/07
KIT ATION EVALU BLE AVAILA
Half-Duplex RS-485-/RS-422-Compatible Transceiver with AutoDirection Control
General Description
The MAX13487E/MAX13488E +5V, half-duplex, ±15kV ESD-protected RS-485/RS-422-compatible transceivers feature one driver and one receiver.
The MAX13487E/ MAX13488E include a hot-swap capability to eliminate false transitions on the bus during power-up or live insertion. The MAX13487E/MAX13488E feature Maxim's proprietary AutoDirection control. This architecture makes the devices ideal for applications, such as isolated RS-485 ports, where the driver input is used in conjunction with the driver-enable signal to drive the differential bus. The MAX13487E features reduced slew-rate drivers that minimize EMI and reduce reflections caused by improperly terminated cables, allowing error-free transmission up to 500kbps. The MAX13488E driver slew rate is not limited, allowing transmit speeds up to 16Mbps. The MAX13487E/MAX13488E feature a 1/4-unit load
