Datasheet MAX15041EVKIT+ - Maxim Даташит SYNCHRONOUS BUCK преобразователь EVALUATION(NW — Даташит
Наименование модели: MAX15041EVKIT+
9 предложений от 8 поставщиков
Версия для разработки, Eval Kit MAX15041 (Low-Cost, 3A, 4.5V to 28V Input, 350kHz, PWM Step-Down DC-DC Regulator with Internal
727GS
MAX15041EVKIT+
Maxim
от 222 ₽
MAX15041EVKIT+
Maxim
5 008 ₽
MAX15041EVKIT+
Maxim
MAX15041EVKIT+
Производитель: Maxim
Описание: SYNCHRONOUS BUCK преобразователь EVALUATION(NW
data sheetСкачать Data Sheet
19-4949; Rev 0; 9/09
MAX15041 Evaluation Kit
General Description
The MAX15041 evaluation kit (EV kit) is a fully assembled and tested circuit board that evaluates the MAX15041 synchronous buck converter IC with integrated high-side and low-side switches.
The EV kit output is configured to 3.3V and delivers up to 3A output current. The EV kit circuit operates at the MAX15041 internally set 350kHz switching frequency and features PCB pads to monitor the IC power-good output signal (PGOOD) and to enable the circuit. The MAX15041 EV kit requires a 4.5V to 28V power supply that provides up to 3A for normal operation.
S 4.5V to 28V Input-Voltage Range S 3.3V at 3A Output S Fixed 350kHz Switching Frequency S Evaluates Internal 170mI RDS-ON High-Side and
На английском языке: Datasheet MAX15041EVKIT+ - Maxim SYNCHRONOUS BUCK CONVERTER EVALUATION(NW
