Datasheet MAX3078EASA+ - Maxim Даташит RS-485/RS-422 TRANSCEIVER ИС — Даташит
Наименование модели: MAX3078EASA+
Купить MAX3078EASA+ на РадиоЛоцман.Цены — от 83 до 1 943 ₽49 предложений от 24 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| MAX3078EASA+T Maxim | 267 ₽ | ||
| MAX3078EASA+T Analog Devices | 676 ₽ | ||
| MAX3078EASA+ Analog Devices | 1 026 ₽ | ||
| MAX3078EASA+T Maxim | по запросу | ||
Производитель: Maxim
Описание: RS-485/RS-422 TRANSCEIVER ИС
19-2668; Rev 2; 4/09
+3.3V, ±15kV ESD-Protected, Fail-Safe, Hot-Swap, RS-485/RS-422 Transceivers
General Description
The MAX3070EMAX3079E 3.3V, ±15kV ESD-protected, RS-485/RS-422 transceivers feature one driver and one receiver.
These devices include fail-safe circuitry, guaranteeing a logic-high receiver output when receiver inputs are open or shorted. The receiver outputs a logic high if all transmitters on a terminated bus are disabled (high impedance). The MAX3070EMAX3079E include a hot-swap capability to eliminate false transitions on the bus during power-up or hot insertion. The MAX3070E/MAX3071E/MAX3072E feature reduced slew-rate drivers that minimize EMI and reduce reflections caused by improperly terminated cables, allowing error-free data transmission up to 250kbps. The MAX3073E/MAX3074E/MAX3075E also feature slewrate-limited drivers but allow transmit speeds up to 500kbps. The MAX3076E/MAX3077E/MAX3078E driver slew rates are not limited, making transmit speeds up to 16Mbp
