Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet MAX3387ECUG+ - Maxim Даташит RECEIVER ИС — Даташит
Maxim MAX3387ECUG+
Наименование модели: MAX3387ECUG+
Производитель: Maxim
Описание: RECEIVER ИС
data sheetСкачать Data Sheet
19-1561; Rev 3; 6/10
3V, ±15kV ESD-Protected, AutoShutdown Plus RS-232 Transceiver for PDAs and Cell Phones
General Description
The MAX3387E 3V powered TIA/EIA-232 and V.28/V.24 is a communications interface with low power requirements, high data-rate capabilities, and enhanced electrostatic discharge (ESD) protection.
The MAX3387E has three receivers and three transmitters. All RS-232 inputs and outputs are protected to ±15kV using the IEC 1000-4-2 Air-Gap Discharge method, ±8kV using the IEC 1000-4-2 Contact Discharge method, and ±15kV using the Human Body Model. A proprietary low-dropout transmitter output stage enables true RS-232 performance from a +3.0V to +5.5V supply with a dual charge pump. The charge pump requires only four small 0.1µF capacitors for operation from a +3.3V supply. The MAX3387E is capable of running at data rates up to 250kbps while maintaining RS-232 compliant output levels. The MAX3387E has a unique VL pin that allows interoperation in mixed-logic voltage s
  • Тип корпуса: TSSOP(NW)
На английском языке: Datasheet MAX3387ECUG+ - Maxim RECEIVER IC
Политика конфиденциальности
