Datasheet MC78M05CDTG - ON Semiconductor Даташит ИС, LDO VOLT REG, 5 В, 0.5 А, D-PAK-3 — Даташит
Наименование модели: MC78M05CDTG
51 предложений от 22 поставщиков Чип стабилизации напряжения, Linear Voltage Regulator, Positive, 5V, 500mA Vout: 5V; TJ = 0° to +125℃, DPAK (SINGLE GAUGE) TO-252, 75-TUBE... | |||
| MC78M05CDTG ON Semiconductor | 16 ₽ | ||
| MC78M05CDTG ON Semiconductor | от 30 ₽ | ||
| MC78M05CDTG ON Semiconductor | от 32 ₽ | ||
| MC78M05CDTG ON Semiconductor | от 46 ₽ | ||
Производитель: ON Semiconductor
Описание: ИС, LDO VOLT REG, 5 В, 0.5 А, D-PAK-3
MC78M00, MC78M00A, NCV78M00 Series 500 mA Positive Voltage Regulators
The MC78M00/MC78M00A Series positive voltage regulators are identical to the popular MC7800 Series devices, except that they are specified for only half the output current.
Like the MC7800 devices, the MC78M00 three-terminal regulators are intended for local, on-card voltage regulation. Internal current limiting, thermal shutdown circuitry and safe-area compensation for the internal pass transistor combine to make these devices remarkably rugged under most operating conditions. Maximum output current, with adequate heatsinking is 500 mA.
Features http://onsemi.com MARKING DIAGRAMS
TO-220 T SUFFIX CASE 221AB Heatsink surface connected to Pin 2. 2 3 xx XX A WL Y WW G 4 1 2 = Voltage Option = Appropriate Suffix Options = Assembly Location = Wafer Lot = Year = Work Week = Pb-Free Package xxxxxG ALYWW
MC 78MxxXXT AWLYWWG
- Входное напряжение минимальное: 10 В
- Output Voltage Fixed: 5 В
- Dropout Voltage Vdo: 2 В
- Количество выводов: 3
- Выходной ток: 500 мА
- Рабочий диапазон температрур: 0°C ... +85°C
- Способ монтажа: SMD
Дополнительные аксессуары:
- STMicroelectronics - LF50ABDT-TR
