Datasheet PCA9622DR,118 - NXP Даташит — Даташит
Наименование модели: PCA9622DR,118
Производитель: NXP
data sheetСкачать Data Sheet
PCA9622
16-bit Fm+ I2C-bus 100 mA 40 V LED driver
Rev.
03 -- 31 August 2009 Product data sheet
1. General description
The PCA9622 is an I2C-bus controlled 16-bit LED driver optimized for voltage switch dimming and blinking 100 mA Red/Green/Blue/Amber (RGBA) LEDs. Each LED output has its own 8-bit resolution (256 steps) fixed frequency individual PWM controller that operates at 97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value. An additional 8-bit resolution (256 steps) group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to either dim or blink all LEDs with the same value. Each LED output can be off, on (no PWM control), set at its individual PWM controller value or at both individual and group PWM controller values. The PCA9622 operates with a supply voltage range of 2.3 V
  • Количество выходов: 16
  • Выходной ток: 100 мА
  • Выходное напряжение: 40 В
  • Диапазон входных напряжений: 2.3 В ... 5.5 В
  • Dimming Control Type: ШИМ
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: TSSOP
  • Switching Frequency: 1 МГц
PCA9622DR118, PCA9622DR 118
На английском языке: Datasheet PCA9622DR,118 - NXP
Политика конфиденциальности
