Datasheet PCA9624PW,112 - NXP Даташит — Даташит
Наименование модели: PCA9624PW,112
Производитель: NXP
PCA9624
8-bit Fm+ I2C-bus 100 mA 40 V LED driver
Rev.
02 -- 26 August 2009 Product data sheet
1. General description
The PCA9624 is an I2C-bus controlled 8-bit LED driver optimized for voltage switch dimming and blinking 100 mA Red/Green/Blue/Amber (RGBA) LEDs. Each LED output has its own 8-bit resolution (256 steps) fixed frequency individual PWM controller that operates at 97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value. An additional 8-bit resolution (256 steps) group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to either dim or blink all LEDs with the same value. Each LED output can be off, on (no PWM control), set at its individual PWM controller value or at both individual and group PWM controller values. The PCA9624 operates with a supply voltage range of 2.3 V t
- Количество выходов: 8
- Выходной ток: 100 мА
- Выходное напряжение: 40 В
- Диапазон входных напряжений: 2.3 В ... 5.5 В
- Dimming Control Type: ШИМ
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: TSSOP
- Switching Frequency: 1 МГц
PCA9624PW112, PCA9624PW 112
