Datasheet PCA9632DP2,118 - NXP Даташит — Даташит
Наименование модели: PCA9632DP2,118
Производитель: NXP
PCA9632
4-bit Fm+ I2C-bus low power LED driver
Rev.
03 -- 15 July 2008 Product data sheet
1. General description
The PCA9632 is an I2C-bus controlled 4-bit LED driver optimized for Red/Green/Blue/Amber (RGBA) color mixing applications. The PCA9632 is a drop-in upgrade for the PCA9633 with 40Ч power reduction. In Individual brightness control mode, each LED output has its own 8-bit resolution (256 steps) fixed frequency Individual PWM controller that operates at 1.5625 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value. In group dimming mode, each LED output has its own 6-bit resolution (64 steps) fixed frequency Individual PWM controller that operates at 6.25 kHz with a duty cycle that is adjustable from 0 % to 98.4 % to allow the LED to be set to a specific brightness value. A fifth 4-bit resolution (16 steps) Group PWM controller has a fixed frequency of 190 Hz that is used to dim all the LEDs with the same value. Wh
- Количество выходов: 4
- Выходной ток: 25 мА
- Выходное напряжение: 5.5 В
- Диапазон входных напряжений: 2.3 В ... 5.5 В
- Dimming Control Type: ШИМ
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: TSSOP
- Switching Frequency: 1 МГц
PCA9632DP2118, PCA9632DP2 118
