Заказные клавиатуры Accord по вашему ТЗ
Datasheet PCA9634PW,112 - NXP Даташит — Даташит
Наименование модели: PCA9634PW,112
Производитель: NXP
data sheetСкачать Data Sheet
PCA9634
8-bit Fm+ I2C-bus LED driver
Rev.
06 -- 12 September 2008 Product data sheet
1. General description
The PCA9634 is an I2C-bus controlled 8-bit LED driver optimized for Red/Green/Blue/Amber (RGBA) color mixing applications. Each LED output has its own 8-bit resolution (256 steps) fixed frequency Individual PWM controller that operates at 97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value. An additional 8-bit resolution (256 steps) Group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to either dim or blink all LEDs with the same value. Each LED output can be off, on (no PWM control), set at its Individual PWM controller value or at both Individual and Group PWM controller values. The LED output driver is programmed to be either open-drain with a 25 mA current sink capa
  • Количество выходов: 8
  • Выходной ток: 25 мА
  • Выходное напряжение: 5.5 В
  • Диапазон входных напряжений: 2.3 В ... 5.5 В
  • Dimming Control Type: ШИМ
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: TSSOP
  • Switching Frequency: 1 МГц
PCA9634PW112, PCA9634PW 112
На английском языке: Datasheet PCA9634PW,112 - NXP
Политика конфиденциальности
