Datasheet PCF8578T/1,112 - NXP Даташит — Даташит
Наименование модели: PCF8578T/1,112
Производитель: NXP
PCF8578
LCD row/column driver for dot matrix graphic displays
Rev.
06 -- 5 May 2009 Product data sheet
1. General description
The PCF8578 is a low power CMOS1 LCD row and column driver, designed to drive dot matrix graphic displays at multiplex rates of 1:8, 1:16, 1:24 or 1:32. The device has 40 outputs, of which 24 are programmable and configurable for the following ratios of rows/columns: 32/8, 24/16, 16/24 or 8/32. The PCF8578 can function as a stand-alone LCD controller and driver for use in small systems. For larger systems it can be used in conjunction with up to 32 PCF8579s for which it has been optimized. Together these two devices form a general purpose LCD dot matrix driver chip set, capable of driving displays of up to 40960 dots. The PCF8578 is compatible with most microcontrollers and communicates via a two-line bidirectional bus (I2C-bus). Communication overhead is minimized by a display RAM with auto-incremented addressing and display bank switching.
- Ток потребления: 20 мкА
- Meter Display Type: LCD
- Интерфейс: I2C
- Диапазон напряжения питания: 2.5 В ... 6 В
- Тип корпуса: VSOP
- Количество выводов: 56
- Рабочий диапазон температрур: -40°C ... +85°C
- Влагостойкость: MSL 1 - Unlimited
PCF8578T/1112, PCF8578T/1 112
