Datasheet SSL1522T/N2,518 - NXP Даташит — Даташит
Наименование модели: SSL1522T/N2,518
Производитель: NXP
SSL152x
SMPS ICs for mains LED drivers
Rev.
3 -- 17 September 2010 Product data sheet
1. General description
The SSL152x family is a Switched Mode Power Supply (SMPS) controller IC that operate directly from the rectified universal AC mains. It is implemented in the high-voltage Easy High Voltage Silicon-On-Insulator (EZ-HV SOI) process, combined with a low-voltage Bipolar Complementary Metal Oxide Semiconductor (BiCMOS) process. The device includes a high-voltage power switch and a start-up circuit that operates directly from the rectified mains voltage. A dedicated circuit for valley switching is built in, which makes a very efficient slim-line electronic concept for solid state lighting applications possible. The SSL152x family can operate in applications with a power range of up to 15 W. Applications in the range between 15 W and 25 W are more suited to the SSL1623PH. LED powers above 25 W are more suited to the SSL1750. In the most basic applications, the SSL152x family act as a
- Topology: Flyback
- Количество выходов: 1
- Рабочий диапазон температрур: -40°C ... +145°C
- Тип корпуса: SOIC
- Switching Frequency: 100 кГц
- Efficiency: 80%
- Влагостойкость: MSL 2 - 1 year
SSL1522T/N2518, SSL1522T/N2 518
