Datasheet SSL1623PH/N1,112 - NXP Даташит — Даташит
Наименование модели: SSL1623PH/N1,112
Производитель: NXP
SSL1623PH
SMPS IC for mains LED drivers
Rev.
02 -- 13 September 2010 Product data sheet
1. General description
The SSL1623PH is a Switched Mode Power Supply (SMPS) controller IC that operates directly from the rectified universal AC mains. It is implemented in the high voltage Easy High Voltage Silicon-On-Insulator (EZ-HV SOI) process, combined with a low voltage Bipolar Complementary Metal Oxide Semiconductor (BiCMOS) process. The device includes a high voltage power switch and a start-up circuit that operates directly from the rectified mains voltage. A dedicated circuit for valley switching is built in, which makes a very efficient slim-line electronic LED driver concept possible. The SSL1623PH can operate in LED applications with a power range of up to 25 W. Applications below 15 W are more suited to the SSL152x family of mains LED drivers. In its most basic version of application the SSL1623PH acts as a voltage source. Here no additional secondary electronics are required. A comb
- Topology: Flyback
- Количество выходов: 1
- Тип корпуса: DIP
- Switching Frequency: 200 кГц
- Efficiency: 80%
SSL1623PH/N1112, SSL1623PH/N1 112
