Datasheet SSL1750T/N1,518 - NXP Даташит — Даташит
Наименование модели: SSL1750T/N1,518
14 предложений от 14 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
SSL1750T/N1518
129 ₽
Эиком
SSL1750T/N1,518
368 ₽
SSL1750T/N1,518
LifeElectronics
SSL1750T/N1,518
Производитель: NXP
data sheetСкачать Data Sheet
SSL1750
SMPS control IC for LED drivers
Rev.
01 -- 15 September 2008 Product data sheet
1. General description
The SSL1750 is a Switched Mode Power Supply (SMPS) controller IC, suitable for driving LED applications from 25 W up to 250 W. For LED power requirements below 25 W the SSL152x family and SSL1623PH are the best choice. The SSL1750 combines a controller for Power Factor Correction (PFC) and a flyback controller. Its high level of integration allows the design of a cost-effective LED power supply with a very low number of external components. The special built-in green functions provide high efficiency at all power levels. This applies to quasi-resonant operation at high power levels, quasi-resonant operation with valley skipping, as well as to reduced frequency operation at lower power levels. At low power levels, the PFC switches over to burst mode control to maintain high efficiency. In burst mode, soft-start and soft-stop functions are added to eliminate audible noise. Duri
  • Topology: Flyback
  • Количество выходов: 1
  • Выходной ток: 700 мА
  • Рабочий диапазон температрур: -20°C ... +150°C
  • Тип корпуса: SOIC
  • Switching Frequency: 125 кГц
  • Влагостойкость: MSL 3 - 168 hours
SSL1750T/N1518, SSL1750T/N1 518
На английском языке: Datasheet SSL1750T/N1,518 - NXP
