Datasheet SSL2101T/N1,518 - NXP Даташит — Даташит
Наименование модели: SSL2101T/N1,518
Производитель: NXP
SSL2101
SMPS IC for dimmable LED lighting
Rev.
04 -- 28 August 2009 Product data sheet
1. General description
The SSL2101 is a Switched Mode Power Supply (SMPS) controller IC that operates in combination with a phase cut dimmer directly from rectified mains. It is designed to drive LED devices. The device includes a high-voltage power switch and a circuit to allow start-up directly from the rectified mains voltage. Furthermore the device includes high-voltage circuitry to supply the phase cut dimmer. For dimmer applications, integrated dedicated circuitry optimizes the dimming curve.
- Количество выходов: 1
- Выходной ток: 900 мА
- Dimming Control Type: ШИМ
- Рабочий диапазон температрур: -40°C ... +100°C
- Тип корпуса: SOIC
- Switching Frequency: 100 кГц
- Влагостойкость: MSL 3 - 168 hours
SSL2101T/N1518, SSL2101T/N1 518
