Datasheet SSL2102T/N1,518 - NXP Даташит — Даташит
Наименование модели: SSL2102T/N1,518
![]() 15 предложений от 12 поставщиков Драйвер LED , LED DRVR 9V/12V/15V/18V/24V 20Pin SO T/R | |||
SSL2102T/N1,518 NXP | 81 ₽ | ||
SSL2102T/N1,518 | 93 ₽ | ||
SSL2102T/N1,518 NXP | по запросу | ||
SSL2102T/N1518 NXP | по запросу |
Производитель: NXP
SSL2102
Mains LED driver IC for dimmable LED lighting
Rev.
01 -- 29 June 2009 Product data sheet
1. General description
The SSL2102 is a Switched Mode Power Supply (SMPS) controller IC that operates in combination with a phase cut dimmer directly from rectified mains. It is designed to drive LED devices. The device includes a high-voltage power switch and a circuit to allow direct start-up from the rectified mains voltage. Furthermore the device includes high-voltage circuitry to supply the phase cut dimmer. For dimmer applications, integrated dedicated circuitry optimizes the dimming curve.
- Количество выходов: 1
- Dimming Control Type: ШИМ
- Рабочий диапазон температрур: -40°C ... +100°C
- Тип корпуса: SOIC
- Switching Frequency: 100 кГц
- Влагостойкость: MSL 3 - 168 hours
SSL2102T/N1518, SSL2102T/N1 518
