Datasheet TJA1054AT,512 - NXP Даташит — Даташит
Наименование модели: TJA1054AT,512
12 предложений от 9 поставщиков
IC TRANSCEIVER HALF 1/1 14SO / 1/1 Transceiver Half CANbus 14-SO
727GS
TJA1054AT,512
от 55 ₽
Hi-Tech Circuit Group
TJA1054AT,512
ТаймЧипс
TJA1054AT,512
SUV System
TJA1054AT,512
Производитель: NXP
data sheetСкачать Data Sheet
TJA1054A
Fault-tolerant CAN transceiver
Rev.
5 -- 3 August 2010 Product data sheet
1. General description
The TJA1054A is the interface between the protocol controller and the physical bus wires in a Controller Area Network (CAN). It is primarily intended for low-speed applications up to 125 kBd in passenger cars. The device provides differential receive and transmit capability but will switch to single-wire transmitter and/or receiver in error conditions. The TJA1054A is the ElectroStatic Discharge (ESD) improved version of the TJA1054. The TJA1054AT is, as the TJA1054T, pin and downwards compatible with the PCA82C252T and the TJA1053T. This means that these two devices can be replaced by the TJA1054AT or the TJA1054T with retention of all functions. The most important improvements of the TJA1054 and the TJA1054A with respect to the PCA82C252 and the TJA1053 are:
  • Диапазон напряжения питания: 4.75 В ... 5.25 В
  • Количество выводов: 14
  • Рабочий диапазон температрур: -40°C ... +150°C
  • Влагостойкость: MSL 2 - 1 year
  • Number of RX Buffers: 1
  • Тип корпуса: SOIC
  • Number of TX Buffers: 1
TJA1054AT512, TJA1054AT 512
На английском языке: Datasheet TJA1054AT,512 - NXP
