Datasheet Texas Instruments TPS65070RSLT — Даташит
СерияTPS65070
МодельTPS65070RSLT
5-канальная ИС управления питанием (PMIC) с 3 DC/DC, 2 LDO в корпусе QFN 6x6 мм 48-VQFN от -40 до 85
TPS65070x Single Chip Power Solution for Battery Powered Systems datasheet
PDF, 2.1 Мб, Версия: H, Файл опубликован: 30 сен 2015
Pin4848
Package TypeRSLRSL
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаTPS65070
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).4.4
Max Height (мм)11
Iout(Max)1.5 A
Iq(Typ)0.08 мА
LDO2
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 36 mm2: 6 x 6(VQFN) PKG
Processor NameOMAP-L1xx,TMS320C674x
Processor SupplierTexas Instruments
Regulated Outputs6
Shutdown Current(Typ)0.08 uA
Special FeaturesComm Control,Power Good,Power Sequencing
Step-Down DC/DC Converter3
Switching Frequency(Max)2250 kHz
Vin(Max)39 В
Vin(Min)1.8 В
Vout(Max)19.2 В
Vout(Min)0.725 В
  • Evaluation Modules & Boards: TPS65070EVM-430
    Evaluation Module for TPS65070 5-Channel Power Management IC
  • TPS6507x Device Comparison
    PDF, 54 Кб, Файл опубликован: 19 фев 2010
    This application report presents an overview of the differences among the TPS65070,TPS65072, TPS65073, TPS650731, and TPS650732 power management integrated circuits (IC). It can assist design engineers in selecting the most suitable IC for their applications.
  • How to Power the TPS6507x On and Off
    PDF, 169 Кб, Файл опубликован: 12 апр 2012
  • Dynamic Power-Path Mgmt & Dynamic Power Mgmt
    PDF, 96 Кб, Файл опубликован: 2 янв 2007
    Dynamic power-path management (DPPM) and dynamic power management (DPM) are two similar types of integrated power management ICs that combine the task of charging a single-cell Li-ion battery and powering the system. Both topologies reduce the battery charging current to give the system priority when the adaptor has reached its output current rating. The bq2403x family and TPS65800 IC use the DPP
  • Powering OMAP-L132/L138, C6742/4/6, and AM18x with TPS65070 (Rev. B)
    PDF, 453 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This documents details the design consideration of a power management unit (PMU) solution for the OMAP-L132/-L138 low-power applications processors with a TPS65070 five-channel power management device.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65070 (2)
  • Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
На английском языке: Datasheet Texas Instruments TPS65070RSLT
