Datasheet FAN7382M - Fairchild Даташит High-Side/Low-Side Gate драйвер ИС — Даташит
Наименование модели: FAN7382M
![]() 62 предложений от 25 поставщиков IC: driver; high-/low-side,контроллер затвора; MillerDriveTM | |||
FAN7382M1X ON Semiconductor | от 25 ₽ | ||
FAN7382M1X ON Semiconductor | 34 ₽ | ||
FAN7382M1X Fairchild | по запросу | ||
FAN7382M Fairchild | по запросу |
Производитель: Fairchild
Описание: High-Side/Low-Side Gate драйвер ИС
FAN7382 High- and Low-Side Gate Driver
February 2007
Features
Floating Channels Designed for Bootstrap Operation to +600V Typically 350mA/650mA Sourcing/Sinking Current Driving Capability for Both Channels Common-Mode dv/dt Noise Canceling Circuit Extended Allowable Negative VS Swing to -9.8V for Signal Propagation at VCC=VBS=15V VCC & VBS Supply Range from 10V to 20V UVLO Functions for Both Channels TTL Compatible Input Logic Threshold Levels Matched Propagation Delay Below 50nsec Output In-phase with Input Signal
- Рассеиваемая мощность: 0.625 Вт
- Sink Output Current: 650 мА
- Device Type: IGBT / MOSFET
- Способ монтажа: SMD
- Output Current, Source Min: 350 мА
- Тип корпуса: SOP
- Количество выводов: 8
