Datasheet NTE6244 - NTE Electronics Даташит FAST RECTIFER, COMMON ANODE, 16 А TO-220 — Даташит
Наименование модели: NTE6244
Купить NTE6244 на РадиоЛоцман.Цены — от 350 до 3 800 ₽17 предложений от 10 поставщиков Силовой диод, NTE ELECTRONICS NTE6244 Fast / Ultrafast Diode, 200V, 16A, Dual Common Anode, 975mV, 35ns, 100A | |||
| NTE6244 NTE Electronics | 510 ₽ | ||
| NTE6244 NTE Electronics | от 777 ₽ | ||
| NTE6244 NTE Electronics | по запросу | ||
| NTE6244 | по запросу | ||
Производитель: NTE Electronics
Описание: FAST RECTIFER, COMMON ANODE, 16 А TO-220
NTE6240 & NTE6244 Silicon Rectifier Super Fast, Dual, Center Tap
Features: D Dual Rectifier Construction: NTE6240 Positive CenterTap NTE6244 Negative CenterTap D Superfast Recovery Times, High Voltage D Low Power Loss, High Efficiency D Low Forward Voltage, High Current Capability D High Temperature Soldering Guaranteed: +250°C @ .250" (6.35mm) from Case for 10sec Applications: D For Use in Low Voltage, High Frequency Inverters, Free Wheeling, and Polarity Protection Applications Maximum Ratings and Electrical Characteristics: (TA = +25°C, resistive or inductive load, for capacitive load, derate current by 20%, unless otherwise specified) Maximum Recurrent Peak Reverse Voltage, VRRM .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200V Maximum RMS Voltage, VRMS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140V Maximum DC Blocking Voltage, VDC . . . . . . . . . . . . . . . . . . . . . . . . . . .
- Diode Configuration: Dual Common Anode
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 200 В
- Forward Current If(AV): 16 А
- Forward Voltage VF Max: 975 мВ
