Datasheet K2401GRP - Littelfuse Даташит Высоковольтный импульсный триак, 250 В, 1 А, DO-15 — Даташит
Littelfuse K2401GRP
40 предложений от 15 поставщиков
Дискретные полупроводники Тиристоры — диаки (двунаправленные), сидаки (для переменного тока)
K2401GRP
Littelfuse
165 ₽
Эиком
K2401GRP
Littelfuse
от 171 ₽
K2401GRP
Littelfuse
от 181 ₽
Hi-Tech Circuit Group
K2401GRP
Littelfuse
Наименование модели: K2401GRP
Производитель: Littelfuse
Описание: Высоковольтный импульсный триак, 250 В, 1 А, DO-15
data sheetСкачать Data Sheet
Teccor® brand Thyristors
MultipulseTM SIDACs
Kxxx1G Series
Description
The MultipulseTM SIDAC is a voltage switch used in MetalHalide lamp ignition circuits as well as High Pressure Sodium lamp ignition circuits for outdoor street and area lighting.
This robust solid state switch is designed to handle lamp igniter applications requiring operation at ambient temperatures up to 90°C where igniter circuit components can raise SIDAC junction temperature up to 125°C, especially when the lamp element is removed or ruptured. Its excellent commutation time (tCOMM) makes this robust product best suited for producing multiple pulses in each half cycle of 50/60 Hz line voltage. The MultipulseTM SIDAC is offered in DO-15 axial leaded package. Kxxx1G SIDAC has a repetitive off-state blocking voltage (VDRM) of 180V to 270V minimum depending actual device type. Blocking capability is ensured by glass passivated junctions for best reliability. Package is epoxy encapsulation with tin-plated copper all
  • Breakover Voltage Range: 220 В ... 250 В
  • Breakover Current Max.: 10 мкА
  • Peak Forward Current: 1 А
  • Thyristor Case: DO-15
  • Количество выводов: 2
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DO-15
На английском языке: Datasheet K2401GRP - Littelfuse SIDAC, 250 V, 1 A, DO-15
