Datasheet RHRG30120 - Fairchild Даташит Диод, мягкий RECOVERY, 30 А — Даташит
Наименование модели: RHRG30120
![]() 49 предложений от 30 поставщиков Быстрый / ультрабыстрый диод, мягкий, 1.2 кВ, 30 А, Одиночный, 3.2 В, 75 нс, 300 А | |||
RHRG30120 Fairchild | 115 ₽ | ||
RHRG30120 ON Semiconductor | 136 ₽ | ||
RHRG30120 ON Semiconductor | от 169 ₽ | ||
RHRG30120 Fairchild | по запросу |
Производитель: Fairchild
Описание: Диод, мягкий RECOVERY, 30 А
RHRG30120
Data Sheet January 2002
30A, 1200V Hyperfast Diode
The RHRG30120 is a hyperfast diode with soft recovery characteristics (trr < 65ns).
It has half the recovery time of ultrafast diodes and is of silicon nitride passivated ion-implanted epitaxial planar construction. This device is intended for use as a freewheeling/clamping diode and rectifier in a variety of high frequency switching power supplies and other power switching applications. Its low stored charge and hyperfast soft recovery minimize ringing and electrical noise in many power switching circuits, thus reducing power loss in the switching transistors. Formerly developmental type TA49041.
Features
- Diode Type: Soft Recovery
- Repetitive Reverse Voltage Vrrm Max: 1.2 кВ
- Forward Current If(AV): 30 А
- Forward Voltage VF Max: 3.2 В
- Reverse Recovery Time trr Max: 75 нс
- Forward Surge Current Ifsm Max: 300 А
- Тип корпуса: TO-247
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Ifsm: 300 А
- Forward Voltage: 3.2 В
- Температура перехода максимальная: 175°C
- Reverse Recovery Time trr Typ: 65 нс
- Способ монтажа: Through Hole
- Current Ifrm: 60 А
Дополнительные аксессуары:
- Fischer Elektronik - FK 243 MI 247 H
- Fischer Elektronik - FK 243 MI 247 O
- Fischer Elektronik - SK 145/25 STS-220
- Fischer Elektronik - WLK 5
