Datasheet RHRP15120 - Fairchild Даташит Диод, FAST, 15 А, 1200 В, SMD — Даташит
Наименование модели: RHRP15120
![]() 53 предложений от 29 поставщиков Быстрый / ультрабыстрый диод, 1.2 кВ, 15 А, Одиночный, 3.2 В, 75 нс, 200 А | |||
RHRP15120 ON Semiconductor | от 3.11 ₽ | ||
RHRP15120 ON Semiconductor | 28 ₽ | ||
RHRP15120 | от 141 ₽ | ||
RHRP15120 ON Semiconductor | от 148 ₽ |
Производитель: Fairchild
Описание: Диод, FAST, 15 А, 1200 В, SMD
RHRP15120
Data Sheet January 2002
15A, 1200V Hyperfast Diode
The RHRP15120 is a hyperfast diode with soft recovery characteristics (trr < 65ns).
It has half the recovery time of ultrafast diodes and is of silicon nitride passivated ion-implanted epitaxial planar construction. This device is intended for use as a freewheeling/clamping diode and rectifier in a variety of switching power supplies and other power switching applications. Its low stored charge and hyperfast soft recovery minimize ringing and electrical noise in many power switching circuits, thus reducing power loss in the switching transistors. Formerly developmental type TA49098.
Features
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 1.2 кВ
- Forward Current If(AV): 15 А
- Forward Voltage VF Max: 3.2 В
- Reverse Recovery Time trr Max: 75 нс
- Forward Surge Current Ifsm Max: 200 А
- Тип корпуса: TO-220AC
- Количество выводов: 2
- SVHC: No SVHC (15-Dec-2010)
- Current Ifsm: 200 А
- Forward Voltage: 3.2 В
- Температура перехода максимальная: 175°C
- Reverse Recovery Time trr Typ: 65 нс
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
- Multicomp - MK3306
