Datasheet RURG3020CC - Fairchild Даташит Диод, мягкий RECOVERY, 2X30A — Даташит
Наименование модели: RURG3020CC
![]() 23 предложений от 18 поставщиков Быстрый / ультрабыстрый диод, 200 В, 30 А, Двойной Общий Катод, 1 В, 45 нс, 325 А | |||
RURG3020CC Harris | 83 ₽ | ||
RURG3020CC ON Semiconductor | 636 ₽ | ||
RURG3020CCS5001 Fairchild | по запросу | ||
RURG3020CC_NL Fairchild | по запросу |
Производитель: Fairchild
Описание: Диод, мягкий RECOVERY, 2X30A
RURG3020CC
Data Sheet January 2002
30A, 200V Ultrafast Dual Diode
The RURG3020CC is an ultrafast dual diode with soft recovery characteristics (trr < 45ns).
It has low forward voltage drop and is of silicon nitride passivated ion-implanted epitaxial planar construction. This device is intended for use as a freewheeling/clamping diode and rectifier in a variety of switching power supplies and other power switching applications. Its low stored charge and ultrafast recovery with soft recovery characteristics minimizes ringing and electrical noise in many power switching circuits reducing power loss in the switching transistors. Formerly developmental type TA09645.
Features
- Diode Type: Soft Recovery
- Repetitive Reverse Voltage Vrrm Max: 200 В
- Forward Current If(AV): 30 А
- Forward Voltage VF Max: 1 В
- Reverse Recovery Time trr Max: 50 нс
- Forward Surge Current Ifsm Max: 325 А
- Тип корпуса: TO-247
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Ifsm: 325 А
- Forward Voltage: 1 В
- Температура перехода максимальная: 175°C
- Reverse Recovery Time trr Typ: 45 нс
- Способ монтажа: Through Hole
- Current Ifrm: 70 А
- Diode Configuration: Dual
Дополнительные аксессуары:
- Fischer Elektronik - FK 243 MI 247 H
- Fischer Elektronik - FK 243 MI 247 O
- Fischer Elektronik - SK 145/25 STS-220
- Fischer Elektronik - WLK 5
