Datasheet IDH02SG120 - Infineon Даташит Диод, Шоттки, 1200 В, 2 А, TO220-2 — Даташит
Наименование модели: IDH02SG120
![]() 15 предложений от 12 поставщиков Диоды Шоттки, INFINEON IDH02SG120XKSA1 Silicon Carbide Schottky Diode, thinQ 2G 1200V Series, Single, 1.2kV, 2A, 7.2NC, TO-220 | |||
IDH02SG120XKSA1 Infineon | 171 ₽ | ||
IDH02SG120XKSA1 Infineon | 441 ₽ | ||
IDH02SG120XKSA1 Infineon | от 2 335 ₽ | ||
IDH02SG120XKSA1 | по запросу |
Производитель: Infineon
Описание: Диод, Шоттки, 1200 В, 2 А, TO220-2
IDH02SG120
3rd Generation thinQ!TM SiC Schottky Diode
Features · Revolutionary semiconductor material - Silicon Carbide · Switching behavior benchmark · No reverse recovery / No forward recovery · Temperature independent switching behavior · High surge current capability · Pb-free lead plating; RoHS compliant · Qualified according to JEDEC1) for target applications · Optimized for high temperature operation · Lowest Figure of Merit QC/IF PG-TO220-2 Product Summary V DC QC I F; T C< 130 °C 1200 600 3.2 7.2 3 2 V nC A
thinQ!TM 3G Diode designed for fast switching applications like: · SMPS e.g.; CCM PFC · Motor Drives; Solar Applications; UPS Type IDH02SG120 Package PG-TO220-2 Marking D02G120 Pin 1 C Pin 2 A
Maximum ratings Parameter Continuous forward current Symbol Conditions IF T C<130 °C T C=25 °C, t p=10 ms T C=150 °C, t p=10 ms T C=25 °C, t p=10 µs T C=25 °C, t p=10 ms T C=150 °C, t p=10 ms V RRM dv/ dt P tot T j, T stg T sold 1.6mm (0.063 in.) from case for 10s M3 and M3.5 screw
- Diode Type: Schottky
- Repetitive Reverse Voltage Vrrm Max: 1.2 кВ
- Forward Current If(AV): 2 А
- Forward Voltage VF Max: 1.8 В
- Reverse Recovery Time trr Max: 10 нс
- Forward Surge Current Ifsm Max: 15 А
+175°C
- Тип корпуса: TO-220
- Количество выводов: 2
Дополнительные аксессуары:
- ABL HEATSINKS - LS85
- Fischer Elektronik - FK 245 MI 247 O
- MULTICORE (SOLDER) - 1399075-M
- Multicomp - MK3311
