Datasheet IDH03SG60C - Infineon Даташит Диод, Шоттки, 600 В, 3 А, TO220-2 — Даташит
Infineon IDH03SG60C
Наименование модели: IDH03SG60C
Диоды Шоттки, INFINEON IDH03SG60C Silicon Carbide Schottky Diode, SIC, thinQ 3G 600V Series, Single, 600V, 3A, 3.2NC, TO-220
IDH03SG60C
Infineon
21 ₽
727GS
IDH03SG60C
109 ₽
TradeElectronics
IDH03SG60C
Infineon
Hi-Tech Circuit Group
IDH03SG60C
Infineon
Производитель: Infineon
Описание: Диод, Шоттки, 600 В, 3 А, TO220-2
data sheetСкачать Data Sheet
IDH03SG60C
3rd Generation thinQ!TM SiC Schottky Diode
Features · Revolutionary semiconductor material - Silicon Carbide · Switching behavior benchmark · No reverse recovery / No forward recovery · Temperature independent switching behavior · High surge current capability · Pb-free lead plating; RoHS compliant · Qualified according to JEDEC1) for target applications · Breakdown voltage tested at 20mA2) · Optimized for high temperature operation · Lowest Figure of Merit QC/IF Product Summary V DC QC I F; T C< 130 °C 600 3.2 3 V nC A
thinQ! 3G Diode designed for fast switching applications like: · SMPS e.g.; CCM PFC · Motor Drives; Solar Applications; UPS Type IDH03SG60C Package PG-TO220-2 Marking D03G60C Pin 1 C Pin 2 A
Maximum ratings Parameter Continuous forward current Symbol Conditions IF T C<130 °C T C=25 °C, t p=10 ms T C=150 °C, t p=10 ms T C=25 °C, t p=10 µs T C=25 °C, t p=10 ms T C=150 °C, t p=10 ms V RRM dv/ dt P tot T j, T stg T sold 1.6mm (0.063 in.) from case for 10s M3 a
  • Diode Type: Schottky
  • Repetitive Reverse Voltage Vrrm Max: 600 В
  • Forward Current If(AV): 3 А
  • Forward Voltage VF Max: 2.3 В
  • Reverse Recovery Time trr Max: 10 нс
  • Forward Surge Current Ifsm Max: 11.5 А
    +175°C
  • Тип корпуса: TO-220
  • Количество выводов: 2
Дополнительные аксессуары:
  • ABL HEATSINKS - LS85
  • Fischer Elektronik - FK 245 MI 247 O
  • MULTICORE (SOLDER) - 1399075-M
  • Multicomp - MK3311
На английском языке: Datasheet IDH03SG60C - Infineon DIODE, SCHOTTKY, 600 V, 3 A, TO220-2
