Datasheet IDH08SG60C - Infineon Даташит Диод, Шоттки, 600 В, 8 А, TO220-2 — Даташит
Наименование модели: IDH08SG60C
![]() 28 предложений от 13 поставщиков Телевизионные диоды, INFINEON IDH08SG60C Silicon Carbide Schottky Diode, SIC, thinQ 3G 600V Series, Single, 600V, 8A, 12NC, TO-220 | |||
IDH08SG60C Infineon | 170 ₽ | ||
IDH08SG60C Infineon | по запросу | ||
Производитель: Infineon
Описание: Диод, Шоттки, 600 В, 8 А, TO220-2
IDH08SG60C
3rd Generation thinQ!TM SiC Schottky Diode
Features · Revolutionary semiconductor material - Silicon Carbide · Switching behavior benchmark · No reverse recovery / No forward recovery · Temperature independent switching behavior · High surge current capability · Pb-free lead plating; RoHS compliant · Qualified according to JEDEC1) for target applications · Breakdown voltage tested at 20mA2) · Optimized for high temperature operation · Lowest Figure of Merit QC/IF Product Summary V DC QC I F; T C< 130 °C 600 12 8 V nC A
thinQ! 3G Diode designed for fast switching applications like: · SMPS e.g.; CCM PFC · Motor Drives; Solar Applications; UPS Type IDH08SG60C Package PG-TO220-2 Marking D08G60C Pin 1 C Pin 2 A
Maximum ratings Parameter Continuous forward current Symbol Conditions IF T C<130 °C T C=25 °C, t p=10 ms T C=150 °C, t p=10 ms T C=25 °C, t p=10 µs T C=25 °C, t p=10 ms T C=150 °C, t p=10 ms V RRM dv/ dt P tot T j, T stg T sold 1.6mm (0.063 in.) from case for 10s M3 an
- Diode Type: Schottky
- Repetitive Reverse Voltage Vrrm Max: 600 В
- Forward Current If(AV): 8 А
- Forward Voltage VF Max: 2.1 В
- Reverse Recovery Time trr Max: 10 нс
- Forward Surge Current Ifsm Max: 42 А
+175°C
- Тип корпуса: TO-220
- Количество выводов: 2
Дополнительные аксессуары:
- ABL HEATSINKS - LS85
- Fischer Elektronik - FK 245 MI 247 O
- MULTICORE (SOLDER) - 1399075-M
- Multicomp - MK3311
