Datasheet AD8226 (Analog Devices) - 8
ОписаниеWide Supply Range, Rail-to-Rail Output Instrumentation Amplifier
Страниц / Страница29 / 8 — Data Sheet. AD8226. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table …
ВерсияC
Формат / Размер файлаPDF / 720 Кб
Data Sheet. AD8226. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter. Rating. Table 5. Thermal Resistance. Package
Data Sheet AD8226 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Thermal Resistance Package
Data Sheet AD8226 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4. Parameter Rating
θJA is specified for a device in free air. Supply Voltage ±18 V
Output Short-Circuit Current Indefinite
Package θ Unit JA
Maximum Voltage at −IN or +IN −V + 40 V S 8-Lead MSOP, 4-Layer JEDEC Board 135 °C/W Minimum Voltage at −IN or +IN +V − 40 V S 8-Lead SOIC, 4-Layer JEDEC Board 121 °C/W REF Voltage ±V S Storage Temperature Range −65°C to +150°C
ESD CAUTION
Specified Temperature Range −40°C to +125°C Maximum Junction Temperature 140°C ESD Human Body Model 1.5 kV Charge Device Model 1.5 kV Machine Model 100 V Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. C | Page 7 of 28 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Architecture Gain Selection Reference Terminal Input Voltage Range Performance Across Temperature Recommendation for Best Performance Layout Common-Mode Rejection Ratio Over Frequency Power Supplies References Input Bias Current Return Path Input Protection Radio Frequency Interference (RFI) Applications Information Differential Drive Tips for Best Differential Output Performance Precision Strain Gage Driving an ADC Outline Dimensions Ordering Guide
