Preliminary Datasheet ADP1074 (Analog Devices) - 4
ОписаниеIsolated Synchronous Forward Controller with Active Clamp and iCoupler
Страниц / Страница14 / 4 — ADP1074. Preliminary Technical Data. SPECIFICATIONS. Table 1. Parameter. …
Формат / Размер файлаPDF / 380 Кб
ADP1074. Preliminary Technical Data. SPECIFICATIONS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
ADP1074 Preliminary Technical Data SPECIFICATIONS Table 1 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
VIN =24V, VDD2 = 12 V, TJ = −40°C to +125°C, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
SUPPLY (primary) Supply Voltage V 4.7 µF capacitor from Vin to PGND1 4.7 24 60 V IN 1 µF capacitor from VREG1 to PGND1 Quiescent Supply Current I V > V , NGATE and PGATE unloaded VIN IN IN_UVLO At 100kHz At 300kHz 3.8 mA At 600kHz 4.4 mA 6.8 mA I V > V , NGATE and PGATE loaded with VIN IN IN_UVLO 2.2nF and 410pF respectively At 100kHz At 300kHz 6 mA At 600kHz 1w2 mA V < 1.2 V, VREG1= 0V, VIN= 60 V EN 24 mA VIN shutdown current 35 µA (VIN + VREG1) startup current I V < 1.2 V, VREG1= 12 V, VIN= 12 V 160 µA VIN_startup EN VIN UVLO VIN rising 4.3 4.5 4.7 V VIN falling 4.3 V UVLO hysteresis EN>1.2 V, 1 µF capacitor on VREG1 -0.1 V Time from EN high to PGATE 1 ms output switching Time from EN low to SR1/2 EN<1.0 V, 1 µF capacitor on VREG1 1 µs output stops switching SUPPLY (secondary) Supply Voltage V 4.7 µF capacitor from VDD2 to PGND2 4.5 12 36 V DD2 1 µF capacitor from VREG2 to PGND2 Quiescent supply current I SR1 and SR2 unloaded DD2 At 100kHz 6.3 mA At 300kHz 6.4 mA At 600kHz 6.9 mA I SR1 and SR2 loaded with 2.2nF DD2 At 100kHz 9 mA At 300kHz 13.5 mA At 600kHz 20 mA UVLO threshold V rising 3.5 V DD2 V falling 3.45 V DD2 UVLO Hysteresis 50 mV Secondary UVLO hiccup time 225 ms OSCILLATOR Switching frequency (f ) R = 480 kΩ (±1%) -10% 50 +10% kHz s RT R = 240 kΩ (±1%) -10% 100 +10% kHz RT R = 120 kΩ (±1%) -10% 200 +10% kHz RT R = 80 kΩ (±1%) -10% 300 +10% kHz RT R = 60 kΩ (±1%) -10% 400 +10% kHz RT R = 40 kΩ (±1%) -10% 600 +10% kHz RT VREG1 pin VREG1 voltage clamp I = 3mA, V < 1.2 V 13.5 14.3 15.2 V VREG EN VREG1 clamp series resistance VREG1 current 5mA and 15mA 16 Ω Rev. PrB | Page 4 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS TYPICAL APPLICATION CIRCUITS SPECIFICATIONS REGULATORY INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS SIMPLIFIED BLOCK DIAGRAM APPLICATIONS INFORMATION INSULATION LIFETIME OUTLINE DIMENSIONS
