Datasheet ADA4530-1 (Analog Devices) - 2
ОписаниеFemtoampere Input Bias Current Electrometer Amplifier
Страниц / Страница51 / 2 — ADA4530-1* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияB
Формат / Размер файлаPDF / 2.0 Мб
ADA4530-1* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADA4530-1* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADA4530-1 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADA4530-1 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all ADA4530-1 EngineerZone Discussions. • AN-1373: ADA4530-1 Femtoampere Level Input Bias Current Measurement
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • UG-865: ADA4530-1 8-Lead SOIC Package Evaluation Board
TECHNICAL SUPPORT
Submit a technical question or find your regional support
TOOLS AND SIMULATIONS
number. • Analog Photodiode Wizard • ADA4530 SPICE Macro-Model
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
REFERENCE MATERIALS Press
• Electrometer-Grade Amplifier Improves Accuracy While Reducing Size of Chemical Analysis Instruments
Technical Articles
• Guarded Limiters Improve High Impedance Sensor Dynamic Range
Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V NOMINAL ELECTRICAL CHARACTERISTICS 10 V NOMINAL ELECTRICAL CHARACTERISTICS 15 V NOMINAL ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MAIN AMPLIFIER, DC PERFORMANCE MAIN AMPLIFIER, AC PERFORMANCE GUARD AMPLIFIER THEORY OF OPERATION ESD STRUCTURE INPUT STAGE GAIN STAGE OUTPUT STAGE GUARD BUFFER APPLICATIONS INFORMATION INPUT PROTECTION SINGLE-SUPPLY AND RAIL-TO-RAIL OUTPUT CAPACITIVE LOAD STABILITY EMI REJECTION RATIO HIGH IMPEDANCE MEASUREMENTS INPUT BIAS CURRENT INPUT RESISTANCE INPUT OFFSET VOLTAGE INSULATION RESISTANCE GUARDING DIELECTRIC RELAXATION HUMIDITY EFFECTS CONTAMINATION CLEANING AND HANDLING SOLDER PASTE SELECTION CURRENT NOISE CONSIDERATIONS LAYOUT GUIDELINES PHYSICAL IMPLEMENTATION OF GUARDING TECHNIQUES GUARD RING GUARD PLANE VIA FENCE CABLES AND CONNECTORS ELECTROSTATIC INTERFERANCE PHOTODIODE INTERFACE DC ERROR ANALYSIS AC ERROR ANALYSIS NOISE ANALYSIS DESIGN RECOMMENDATIONS DESIGN EXAMPLE POWER SUPPLY RECOMMENDATIONS POWER SUPPLY CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
