Datasheet AD706 (Analog Devices) - 6
ОписаниеDual Picoampere Input Current Bipolar Op Amp
Страниц / Страница13 / 6 — AD706. 1000. 100. 0.5. 10k. 20M. VOUT. CURRENT NOISE – fA/. VOLTAGE NOISE …
ВерсияG
Формат / Размер файлаPDF / 251 Кб
AD706. 1000. 100. 0.5. 10k. 20M. VOUT. CURRENT NOISE – fA/. VOLTAGE NOISE – nV/. FREQUENCY – Hz. TIME – Seconds. 160. 180. 140. 900. 120. 800. +125. – PSRR
AD706 1000 100 0.5 10k 20M VOUT CURRENT NOISE – fA/ VOLTAGE NOISE – nV/ FREQUENCY – Hz TIME – Seconds 160 180 140 900 120 800 +125 – PSRR
AD706 1000 1000
Hz
Hz 100 100 0.5 V 100 10k 10 10 20M VOUT CURRENT NOISE – fA/ VOLTAGE NOISE – nV/ 1 1 1 10 100 1000 1 10 100 1000 0 5 10 FREQUENCY – Hz FREQUENCY – Hz TIME – Seconds
TPC 10. Input Noise Voltage TPC 11. Input Noise Current TPC 12. 0.1 Hz to 10 Hz Spectral Density Spectral Density Noise Voltage
1000 160 180 140 160 A 900 120 140 100 120 800 80 100 +125 C – PSRR CMRR – dB 60 PSRR – dB 80 +25 C + PSRR 700 40 60 QUIESCENT CURRENT – 20 40 –55 C 600 0 20 0 5 10 15 20 0.1 1 10 100 1k 10k 100k 1M 0.1 1 10 100 1k 10k 100k 1M SUPPLY VOLTAGE – Volts FREQUENCY – Hz FREQUENCY – Hz
TPC 13. Quiescent Supply TPC 14. Common-Mode Rejection TPC 15. Power Supply Rejection Current vs. Supply Voltage Ratio vs. Frequency Ratio vs. Frequency
140 0 +V 10M S 120 30 –0.5 –55 C 100 60 –1.0 rees PHASE g +25 C 80 90 –1.5 +125 C 60 120 1M 40 150 +1.5 GAIN 20 180 +1.0 PHASE SHIFT – De OPEN-LOOP VOLTAGE GAIN 0 210 (REFERRED TO SUPPLY VOLTAGES) +0.5 OPEN-LOOP VOLTAGE GAIN – dB OUTPUT VOLTAGE SWING – Volts –20 240 –VS 100k1 2 4 6 8 10 100 0.01 0.1 1 10 100 1k 10k 100k 1M 10M 0 5 10 15 20 LOAD RESISTANCE – k FREQUENCY – Hz SUPPLY VOLTAGE – Volts
TPC 16. Open-Loop Gain vs. Load TPC 17. Open-Loop Gain and TPC 18. Output Voltage Swing vs. Resistance vs. Load Resistance Phase Shift vs. Frequency Supply Voltage REV. E –5– Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM PRODUCT HIGHLIGHTS GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALIZATION PHOTOGRAPH Typical Performance Characteristics 1 Hz, 4-Pole, Active Filter OUTLINE DIMENSIONS Revision History
