Datasheet AD713 (Analog Devices) - 4
ОписаниеPrecision, High Speed, BiFET Quad Op Amp
Страниц / Страница21 / 4 — AD713. SPECIFICATIONS. Table 1. AD713J/AD713A. Parameter Test. …
ВерсияC
Формат / Размер файлаPDF / 387 Кб
AD713. SPECIFICATIONS. Table 1. AD713J/AD713A. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
AD713 SPECIFICATIONS Table 1 AD713J/AD713A Parameter Test Conditions/Comments Min Typ Max Unit
15 предложений от 15 поставщиков
Зенер
Россия и страны ТС
AD713JR-16-REEL7
1 740 ₽
МосЧип
AD713JR-16-REEL7_OEM_SUR
AD713JR-16-REEL7
AD713JR-16-REEL7
link to page 21 link to page 21 link to page 5 link to page 5 link to page 5 link to page 5
VS = ±15 V at TA = 25°C, unless otherwise noted.
Table 1. AD713J/AD713A Parameter Test Conditions/Comments Min Typ Max Unit
INPUT OFFSET VOLTAGE1 Initial Offset 0.3 1.5 mV Offset TMIN to TMAX 0.5 2 mV vs. Temp 5 μV/°C vs. Supply 78 95 dB TMIN to TMAX 76 95 dB Long-Term Stability 15 μV/Month INPUT BIAS CURRENT2 VCM = 0 V 40 150 pA VCM = 0 V at TMAX 3.4/9.6 nA VCM = ±10 V 55 200 pA INPUT OFFSET CURRENT VCM = 0 V 10 75 pA VCM = 0 V at TMAX 1.7/4.8 pA MATCHING CHARACTERISTICS Input Offset Voltage 0.5 1.8 mV TMIN to TMAX 0.7 2.3 mV Input Offset Voltage Drift 8 μV/°C Input Bias Current 10 100 pA Crosstalk f = 1 kHz −130 dB f = 100 kHz −95 dB FREQUENCY RESPONSE Small Signal Bandwidth G = −1 3.0 4.0 MHz Full Power Response VO = 20 V p-p 200 kHz Slew Rate G = −1 16 20 V/μs Settling Time to 0.01% 1.0 1.2 μs Total Harmonic Distortion f = 1 kHz; RL ≥ 2 kΩ; VO = 3 V rms 0.0003 % INPUT IMPEDANCE Differential3 3 × 1012||5.5 Ω||pF Common Mode4 3 × 1012||5.5 Ω||pF INPUT VOLTAGE RANGE Differential ±20 V Common-Mode Voltage +14.5/−11.5 V TMIN to TMAX −11 +13 V Common Mode VCM = ±10 V 78 88 dB Rejection Ratio TMIN to TMAX 76 84 dB VCM = ±11 V 72 84 dB TMIN to TMAX 70 80 dB INPUT VOLTAGE NOISE 0.1 Hz to 10 Hz 2 μV p-p f = 10 Hz 45 nV/√Hz f = 100 Hz 22 nV/√Hz f = 1 kHz 18 nV/√Hz f = 10 kHz 16 nV/√Hz INPUT CURRENT NOISE f = 1 kHz 0.01 pA/√Hz OPEN-LOOP GAIN VO = ±10 V; RL ≥ 2 kΩ 150 400 V/mV TMIN to TMAX 100 V/mV Rev. F | Page 3 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION MEASURING AD713 SETTLING TIME POWER SUPPLY BYPASSING A HIGH SPEED INSTRUMENTATION AMPLIFIER CIRCUIT A HIGH SPEED 4-OP-AMP CASCADED AMPLIFIER CIRCUIT HIGH SPEED OP AMP APPLICATIONS AND TECHNIQUES DAC Buffers (I-to-V Converters) Driving the Analog Input of an Analog-to-Digital Converter Driving A Large Capacitive Load CMOS DAC APPLICATIONS FILTER APPLICATIONS A Programmable State Variable Filter GIC AND FDNR FILTER APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
