Datasheet AD745 (Analog Devices) - 6
ОписаниеUltralow Noise, High Speed, BiFET Op Amp
Страниц / Страница13 / 6 — AD745. 120. 150. RL = 2k. 100. 140. PHASE. dB 80. 130. CLOSED-LOOP GAIN = …
ВерсияD
Формат / Размер файлаPDF / 373 Кб
AD745. 120. 150. RL = 2k. 100. 140. PHASE. dB 80. 130. CLOSED-LOOP GAIN = 5. GAIN. SLEW RA. OPEN-LOOP GAIN. –20. 10k. 100k. 10M. 100M. –60 –40 –20 0. 40 60
AD745 120 150 RL = 2k 100 140 PHASE dB 80 130 CLOSED-LOOP GAIN = 5 GAIN SLEW RA OPEN-LOOP GAIN –20 10k 100k 10M 100M –60 –40 –20 0 40 60
Микросхема Буферный усилитель, IC OPAMP JFET 20MHz 16SOIC
AD745KR-16-REEL7
919 ₽
AD745KR-16-REEL7
2 110 ₽
AD745KR-16-REEL7
AD745KR-16-REEL7
AD745 120 14 150 RL = 2k 100 140 PHASE dB 80 dB s 12 V/ 130 60 TE 40 CLOSED-LOOP GAIN = 5 GAIN 120 10 20 SLEW RA OPEN-LOOP GAIN OPEN-LOOP GAIN 100 0 –20 8 80 100 1k 10k 100k 1M 10M 100M –60 –40 –20 0 20 40 60 80 100 110 120 0 5 10 15 20 FREQUENCY – Hz TEMPERATURE – C SUPPLY VOLTAGE VOLTS
TPC 10. Open-Loop Gain and Phase TPC 11. Slew Rate vs. Temperature TPC 12. Open-Loop Gain vs. vs. Frequency Supply Voltage
120 120 35 RL = 2k dB 110 30 dB 100 p-p +SUPPLY V – 100 25 80 90 SWING 20 60 Y REJECTION GE A 80 15 –SUPPLY T L V O cm = 10V 40 70 10 WER SUPPL 20 COMMON-MODE REJECTION 60 PO OUTPUT V 5 50 0 0 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M 100M 10k 100k 1M 10M FREQUENCY – Hz FREQUENCY – Hz FREQUENCY – Hz
TPC 13. Common-Mode Rejection vs. TPC 14. Power Supply Rejection TPC 15. Large Signal Frequency Frequency vs. Frequency Response
–40 1.0 100 1k dB % fA/ Hz nV/ Hz –60 0.1 ION (THD) ION (THD) T T 10 100 R –80 0.01 R O O CLOSED-LOOP GAIN = 5 rred to input) GAIN = +10 e –100 0.001 GAIN = +100 GAIN = –4 GE (ref 1.0 10 A T L –120 0.0001 O L HARMONIC DIST L HARMONIC DIST V A A T T O O T T –140 0.00001 NOISE 0.1 1.0 10 100 1k 10k 100k 10 100 1k 10k 100k 1M 10M CURRENT NOISE SPECTRAL DENSITY 1 10 100 1k 10k 100k FREQUENCY – Hz FREQUENCY – Hz FREQUENCY – Hz
TPC 16. Total Harmonic Distortion TPC 17. Input Noise Voltage TPC 18. Input Noise Current vs. Frequency Spectral Density Spectral Density REV. D –5–
