Datasheet AD8001 (Analog Devices) - 3
Описание800 MHz, 50 mW Current Feedback Amplifier
Страниц / Страница17 / 3 — AD8001–SPECIFICATIONS (@ TA = + 25. C, VS =. 5 V, RL = 100. , unless …
ВерсияD
Формат / Размер файлаPDF / 331 Кб
AD8001–SPECIFICATIONS (@ TA = + 25. C, VS =. 5 V, RL = 100. , unless otherwise noted.). AD8001A. Model. Conditions. Min. Typ. Max. Unit
AD8001–SPECIFICATIONS (@ TA = + 25 C, VS = 5 V, RL = 100 , unless otherwise noted.) AD8001A Model Conditions Min Typ Max Unit
17 предложений от 16 поставщиков
AD8001ART-REEL7
60 ₽
AD8001ART-REEL7
118 ₽
AD8001ART-REEL7
459 ₽
SUV System
AD8001ART-REEL7
AD8001
DYNAMIC PERFORMANCE –3 dB Small Signal Bandwidth, N Package G = +2, < 0.1 dB Peaking, RF = 750 Ω 350 440 MHz G = +1, < 1 dB Peaking, RF = 1 kΩ 650 880 MHz R Package G = +2, < 0.1 dB Peaking, RF = 681 Ω 350 440 MHz G = +1, < 0.1 dB Peaking, RF = 845 Ω 575 715 MHz RT Package G = +2, < 0.1 dB Peaking, RF = 768 Ω 300 380 MHz G = +1, < 0.1 dB Peaking, RF = 1 kΩ 575 795 MHz Bandwidth for 0.1 dB Flatness N Package G = +2, RF = 750 Ω 85 110 MHz R Package G = +2, RF = 681 Ω 100 125 MHz RT Package G = +2, RF = 768 Ω 120 145 MHz Slew Rate G = +2, VO = 2 V Step 800 1000 V/µs G = –1, VO = 2 V Step 960 1200 V/µs Settling Time to 0.1% G = –1, VO = 2 V Step 10 ns Rise and Fall Time G = +2, VO = 2 V Step, RF = 649 Ω 1.4 ns NOISE/HARMONIC PERFORMANCE Total Harmonic Distortion fC = 5 MHz, VO = 2 V p-p –65 dBc G = +2, RL = 100 Ω Input Voltage Noise f = 10 kHz 2.0 nV/√Hz Input Current Noise f = 10 kHz, +In 2.0 pA/√Hz –In 18 pA/√Hz Differential Gain Error NTSC, G = +2, RL = 150 Ω 0.01 0.025 % Differential Phase Error NTSC, G = +2, RL = 150 Ω 0.025 0.04 Degree Third Order Intercept f = 10 MHz 33 dBm 1 dB Gain Compression f = 10 MHz 14 dBm SFDR f = 5 MHz –66 dB DC PERFORMANCE Input Offset Voltage 2.0 5.5 mV TMIN–TMAX 2.0 9.0 mV Offset Drift 10 µV/°C –Input Bias Current 5.0 25 ±µA TMIN–TMAX 35 ±µA +Input Bias Current 3.0 6.0 ±µA TMIN–TMAX 10 ±µA Open-Loop Transresistance VO = ± 2.5 V 250 900 kΩ TMIN–TMAX 175 kΩ INPUT CHARACTERISTICS Input Resistance +Input 10 MΩ –Input 50 Ω Input Capacitance +Input 1.5 pF Input Common-Mode Voltage Range 3.2 ±V Common-Mode Rejection Ratio Offset Voltage VCM = ± 2.5 V 50 54 dB –Input Current VCM = ± 2.5 V, TMIN–TMAX 0.3 1.0 µA/V +Input Current VCM = ± 2.5 V, TMIN–TMAX 0.2 0.7 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing RL = 150 Ω 2.7 3.1 ±V Output Current RL = 37.5 Ω 50 70 mA Short Circuit Current 85 110 mA POWER SUPPLY Operating Range ±3.0 ±6.0 V Quiescent Current TMIN–TMAX 5.0 5.5 mA Power Supply Rejection Ratio +VS = +4 V to +6 V, –VS = –5 V 60 75 dB –VS = – 4 V to – 6 V, +VS = +5 V 50 56 dB –Input Current TMIN–TMAX 0.5 2.5 µA/V +Input Current TMIN–TMAX 0.1 0.5 µA/V Specifications subject to change without notice. –2– REV. D Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION Choice of Feedback and Gain Resistors Printed Circuit Board Layout Considerations Power Supply Bypassing DC Errors and Noise Driving Capacitive Loads Communications Operation as a Video Line Driver Driving A-to-D Converters Layout Considerations OUTLINE DIMENSIONS Revision History
