Datasheet NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074 (ON Semiconductor) - 9
ПроизводительON Semiconductor
ОписаниеOperational Amplifier, Wide supply range, 3Mhz CMOS Op-Amp
Страниц / Страница25 / 9 — NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074. ELECTRICAL …
Версия14
Формат / Размер файлаPDF / 950 Кб
NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074. ELECTRICAL CHARACTERISTICS AT VS = 10 V. Parameter. Symbol
NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074 ELECTRICAL CHARACTERISTICS AT VS = 10 V Parameter Symbol
22 предложений от 7 поставщиков
IC OPAMP GP 1 CIRCUIT SOT553. General Purpose Amplifier 1 Circuit Rail-to-Rail SOT-553. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
NCV20071XV53T2G
от 35 ₽
Элитан
NCV20071XV53T2G
36 ₽
NCV20071XV53T2G
47 ₽
NCV20071XV53T2G
link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10
TA = 25°C; RL ≥ 10 kW; VCM = VOUT = mid−supply unless otherwise noted. All limits are guaranteed by testing or statistical analysis. Boldface limits apply over the specified temperature range, TA = −40°C to 125°C. (Notes 17, 18)
Parameter Symbol Conditions Min Typ Max Unit INPUT CHARACTERISTICS
1.3 ±3.5 mV Input Offset Voltage VOS NCx20071 +
4.5 mV
1.3 ±3 mV Input Offset Voltage VOS NCx20072, NCx20074 +
4 mV
Offset Voltage Drift DVOS/DT TA = 25°C to 125°C 2 mV/°C 5 200 Input Bias Current (Note 18) IIB pA
1500
2 75 NCx20071, NCx20072
500
Input Offset Current (Note 18) IOS pA 2 75 NCx20074
200
NCx20072 100 Channel Separation XTLK DC dB NCx20074 115 Differential Input Resistance RID 5 GW Common Mode Input Resistance RIN 5 GW Differential Input Capacitance CID 1.5 pF Common Mode Input Capacitance CCM 3.5 pF 110 130 Common Mode Rejection Ratio CMRR VCM = VSS + 0.2 V to VDD − 1.35 V dB
87 OUTPUT CHARACTERISTICS
98 120 Open Loop Voltage Gain AVOL dB
88
Op amp sinking current 50 Output Current Capability (Note 19) IO mA Op amp sourcing current 65 0.023 0.08 Output Voltage High VOH Voltage output swing from positive rail V
0.10
0.022 0.3 Output Voltage Low VOL Voltage output swing from negative rail V
0.35 AC CHARACTERISTICS
Unity Gain Bandwidth UGBW CL = 25 pF 3 MHz Slew Rate at Unity Gain SR CL = 20 pF, RL = 2 kW 2.6 V/ms Phase Margin öm CL = 25 pF 50 ° Gain Margin Am CL = 25 pF 14 dB V Settling time to 0.1% 3.4 Settling Time t O = 8.5 Vpp, S ms Gain = 1, CL = 20 pF Settling time to 0.01% 6.8 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 17. Refer to ABSOLUTE MAXIMUM RATINGS and APPLICATION INFORMATION for Safe Operating Area. 18. Performance guaranteed over the indicated operating temperature range by design and/or characterization. 19. Power dissipation must be limited to prevent junction temperature from exceeding 150°C. See Absolute Maximum Ratings for more infor- mation.
www.onsemi.com 9
