Datasheet MAX4236, MAX4237 (Maxim) - 3
ПроизводительMaxim
ОписаниеSOT23, Very High Precision, 3V/5V Rail-to-Rail Op Amps
Страниц / Страница14 / 3 — SOT23, Very High Precision, 3V/5V. Rail-To-Rail Op Amps. MAX4236/MAX4237
Формат / Размер файлаPDF / 466 Кб
SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps MAX4236/MAX4237
45 предложений от 20 поставщиков
MAX4236BESA+
Maxim
от 43 ₽
ЧипСити
MAX4236BESA+T
Maxim
60 ₽
MAX4236BESA+
от 293 ₽
ТаймЧипс
MAX4236BESA+
Maxim
SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps MAX4236/MAX4237 ELECTRICAL CHARACTERISTICS (SO-8 and µMAX-8) (continued)
(VCC = +2.4V to +5.5V, VEE = 0, VCM = 0, VOUT = VCC/2, RL = 100kΩ to VCC/2, TA = TMIN to TMAX, unless otherwise noted. Typical values are at VCC = +5V and TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
RL = 100kΩ, VOUT = 110 128 VCC = +5V, RL 15mV to (VCC - 50mV) connected to VCC/2, RL = 1kΩ, VOUT = T 105 114 A = +25oC 0.15V to (VCC - 0.3V) VCC = +5V, RL RL = 100kΩ, VOUT = 110 connected to 15mV to (VCC - 50mV) VCC/2, T R A = TMIN to L = 1kΩ, T V 100 MAX OUT = 0.15V to (VCC - 0.3V) Large-Signal Voltage Gain AVOL dB RL = 100kΩ, VOUT = 110 128 VCC = +3V, RL 15mV to (VCC - 50mV) connected to V R CC/2, L = 1kΩ, T V 100 114 A = +25oC OUT = 0.15V to (VCC - 0.3V) RL = 100kΩ, VOUT = VCC = +3V, RL 105 15mV to (VCC - 50mV) connected to VCC/2, RL = 1kΩ, TA = TMIN to VOUT = 0.15V 95 TMAX to (VCC - 0.3V) VCC - VOH 2 10 VCC = +5V, RL connected to VCC /2, RL = 100kΩ VOL - VEE 3 10 Output Voltage Swing VOUT mV VCC - VOH 150 250 VCC = +5V, RL connected to VCC/2, RL = 1kΩ VOL - VEE 50 100 Shorted to VEE 10 Output Short-Circuit Current IOUT(SC) mA Shorted to VCC 30 MAX4236 1.7 Gain-Bandwidth Product GBWP RL = ∞, CL = 5pF MHz MAX4237 7.5 MAX4236 0.3 Slew Rate SR VCC = +5V, VOUT = 4V step V/µs MAX4237 1.3 V settling to within MAX4236 1 Settling Time t OUT S µs 0.01% MAX4237 1 f = 5kHz, V = 2Vp-p, V Total Harmonic Distortion THD OUT CC = +5V RL = 10kΩ 0.001 %
_______________________________________________________________________________________ 3
