Datasheet OP77 (Analog Devices) - 15
ОписаниеNext Generation OP07, Ultralow Offset Voltage Operational Amplifier
Страниц / Страница17 / 15 — OP77. Data Sheet. +15V. 0.1µF. 100kΩ. VIN. 1kΩ. TRIM. 50kΩ. VTH. 1N4148. …
ВерсияG
Формат / Размер файлаPDF / 407 Кб
OP77. Data Sheet. +15V. 0.1µF. 100kΩ. VIN. 1kΩ. TRIM. 50kΩ. VTH. 1N4148. REF-02. 2kΩ. OUT. Rb1. 1.5kΩ. TEMP. GND. Rbp. –15V. Table 8. Resistor Values
OP77 Data Sheet +15V 0.1µF 100kΩ VIN 1kΩ TRIM 50kΩ VTH 1N4148 REF-02 2kΩ OUT Rb1 1.5kΩ TEMP GND Rbp –15V Table 8 Resistor Values
OP77 Data Sheet C +15V C 0.1µF +15V RF 2 100kΩ 0.1µF VIN Ra R 6 c V R O S 1kΩ D1 5 2 7 TRIM 50kΩ VTH 1N4148 R1 6 V REF-02 2kΩ OP77 OUT V OP77 3 Rb1 1.5kΩ OUT V 3 IN 4 TEMP 0.1µF 0.1µF GND 4 Rbp
038 039
–15V –15V
00320- 00320- Figure 36. Precision Threshold Detector/Amplifier Figure 37. Precision Temperature Sensor When VIN < VTH, amplifier output swings negative, reversing the
biasing diode D1. VO = VTH if RL= ∞ when VIN > VTH, the loop
TCVOUT Slope (S) 10 mV/°C 100 mV/°C 10 mV/°F
closes, Temperature Range −55°C to −55°C to −67°F to +125°C +125°C +257°C V = V + (V − R O TH IN V )  F TH 1 +   R Output Voltage −0.55 V to −5.5 V to −0.67 V to S  Range +1.25 V +12.5V +2.57V CC is selected to smooth the response of the loop. Zero-Scale 0 V @ 0°C 0 V @ 0°C 0 V @ 0°F Ra (±1% Resistor) 9.09 kΩ 15 kΩ 7.5 kΩ Rb1 (±1% Resistor) 1.5 kΩ 1.82 kΩ 1.21 kΩ Rbp (Potentiometer) 200 Ω 500 Ω 200 Ω Rc (±1% Resistor) 5.11 kΩ 84.5 kΩ 8.25 kΩ
7 V+ R2A1 (OPTIONAL R2B1 R7 NULL) C1 1 8 R1A R1B Q19 Q9 Q10 Q11 Q12 R9 6 Q7 Q8 OUTPUT Q5 Q3 Q6 Q4 C3 C2 Q17 Q27 R10 3 Q16 R3 NONINVERTING R5 Q20 INPUT Q1 Q26 Q21 Q23 2 Q15 R4 Q22 Q24 Q25 INVERTING Q2 Q18 INPUT Q14 R6 R8 Q13 4 V–
003
1R2A AND R2B ARE ELECTRONICALLY ADJUSTED ON CHIP AT FACTORY.
00320- Figure 38. Simplified Schematic Rev. G | Page 14 of 16 Document Outline Features Pin Connections General Description Table of Contents Revision History Specifications Electrical Specifications Wafer Test Limits Typical Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Test Circuits Applications Precision Current Sinks Outline Dimensions Ordering Guide
