Datasheet LT1719 (Analog Devices) - 3
Описание4.5ns Single/Dual Supply 3V/5V Comparator with Rail-to-Rail Output
Страниц / Страница22 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 220 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
39 предложений от 18 поставщиков
Микросхема Компаратор, LINEAR TECHNOLOGY LT1719CS6#TRMPBF Analog Comparator, Single, High Speed, 1, 4.5ns, 2.7V to 6V, TSOT, 6Pins
ЧипСити
LT1719CS6#TRMPBF
36 ₽
LT1719CS6#TRMPBF
178 ₽
LT1719CS6#TRMPBF
301 ₽
LT1719CS6#TRMPBF
LT1719
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCM = 1V, VSHDN = 0.5V, VOVERDRIVE = 20mV, COUT = 10pF and for the LT1719S8 VCC = +VS = 5V and VEE = –5V, for the LT1719S6 V+ = 5V, V– = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC – VEE Input Supply Voltage (LT1719S8 Only) l 2.7 10.5 V + VS Output Supply Voltage (LT1719S8 Only) l 2.7 6 V V+ – V– Supply Voltage (LT1719CS6 Only) l 2.7 6 V VCMR Input Voltage Range (Note 2) (LT1719S8) l VEE – 0.1 VCC – 1.2 V (LT1719S6) l V– – 0.1 V+ – 1.2 V V + TRIP Input Trip Points (Note 3) l –1.5 5.5 mV V – TRIP l –5.5 1.5 mV VOS Input Offset Voltage (Note 3) 0.4 2.5 mV l 3.5 mV VHYST Input Hysteresis Voltage (Note 3) l 2.0 3.5 7 mV ΔVOS/ΔT Input Offset Voltage Drift l 10 μV/°C IB Input Bias Current l –6 –2.5 0 μA IOS Input Offset Current l 0.2 0.6 μA CMRR Common Mode Rejection Ratio (Note 4) (LT1719S8) l 55 70 dB (Note 5) (LT1719S6) l 55 65 dB PSRR Power Supply Rejection Ratio (Note 6) (LT1719S8) 65 80 dB (Note 7) (LT1719S6) 65 80 dB AV Voltage Gain (Note 8) ∞ V + OH Output High Voltage ISOURCE = 4mA, VIN = VTRIP + 10mV (LT1719S8) l +VS – 0.4 V (LT1719S6) l V+ – 0.4 V V – OL Output Low Voltage ISINK = 10mA, VIN = VTRIP – 10mV l 0.4 V tPD20 Propagation Delay VOVERDRIVE = 20mV (Note 9) VEE = 0V(LT1719S8) 4.5 6.5 ns V– = 0V(LT1719S6) l 8.0 ns VOVERDRIVE = 20mV, VEE = –5V (LT1719S8 Only) 4.2 ns tPD5 Propagation Delay VOVERDRIVE = 5mV (Notes 9, 10) VEE = 0V(LT1719S8) 7 10 ns V– = 0V(LT1719S6) l 13 ns tSKEW Propagation Delay Skew (Note 11) 0.5 1.5 ns tr Output Rise Time 10% to 90% 2.5 ns tf Output Fall Time 90% to 10% 2.2 ns t + JITTER Output Timing Jitter VIN = 1.2VP-P (6dBm), ZIN = 50Ω tPD 15 psRMS f = 20MHz t – PD 11 psRMS fMAX Maximum Toggle Frequency VOVERDRIVE = 50mV, +VS or V+ = 3V 70 MHz VOVERDRIVE = 50mV, +VS or V+ = 5V 62.5 MHz tOFF Turn-Off Delay Time to ZOUT ≥10kΩ 75 ns tON Wake-Up Delay Time to VOH or VOL, ILOAD = 1mA 350 ns ICC Positive Input Stage Supply Current + VS = VCC = 5V, VEE = –5V l 1 2.2 mA (LT1719S8 Only) + VS = VCC = 3V, VEE = 0V l 0.9 1.8 mA IEE Negative Input Stage Supply Current + VS = VCC = 5V, VEE = –5V l –4.8 –2.6 mA (LT1719S8 Only) + VS = VCC = 3V, VEE = 0V l –3.8 –2.2 mA 1719fa 3
