Datasheet LTC1041 (Analog Devices) - 2
ОписаниеBANG-BANG Controller
Страниц / Страница8 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). (OBSOLETE). …
Формат / Размер файлаPDF / 176 Кб
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). (OBSOLETE). OBSOLETE PACKAGE. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) (OBSOLETE) OBSOLETE PACKAGE ELECTRICAL CHARACTERISTICS The
17 предложений от 17 поставщиков
IC BANG-BANG CONTROLLER 8SOIC. Power Supply Controller Bang-Bang Controller 8-SOIC. PMIC - Power Supply Controllers, Monitors
Рутоника
LTC1041CS8#PBF
240 ₽
SUV System
LTC1041CS8#TRPBF
LTC1041CS8#TRPBF
727GS
LTC1041CS8
LTC1041
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
TOP VIEW ORDER PART Total Supply Voltage (V+ to V –) .. 18V ON / OFF 1 8 V+ NUMBER Input Voltage .. (V+ + 0.3V) to (V – – 0.3V) V 2 7 IN VP-P Operating Temperature Range LTC1041CN8 SET POINT 3 6 OSC LTC1041C ... – 40°C to 85°C LTC1041CS8 GND 4 5 DELTA LTC1041M
(OBSOLETE)
.. – 55°C to125°C N8 PACKAGE S8 PACKAGE Storage Temperature Range ... – 55°C to 150°C 8-LEAD PDIP 8-LEAD PDIP TJMAX = 110°C, θJA = 150°C/W (N8) Lead Temperature (Soldering, 10 sec).. 300°C TJMAX = 150°C, θJA = 150°C/W (S8) Output Short Circuit Duration ... Continuous J8 PACKAGE LTC1041MJ8 8-LEAD CERDIP TJMAX = 150°C, θJA = 100°C/W
OBSOLETE PACKAGE
Consider the N8 Package as an Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. Test Conditions: V+ = 5V, unless otherwise specified. TC1041M/LTC1041C SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SET POINT Error (Note 3) V + = 2.8V to 6V (Note 2) ±0.3 ±0.5 mV ● + + ±0.05 ±0.1 % of DELTA V + = 6V to 15V (Note 2) ±1 ±3 mV ● + + ±0.05 ±0.1 % of DELTA Deadband Error (Note 4) V + = 2.8V to 6V (Note 2) ±0.6 ±1 mV ● + + ±0.1 ±0.2 % of DELTA V + = 6V to 15V (Note 2) ±2 ±6 ● + + ±0.1 ±0.2 % of DELTA IOS Input Current V + = 5V, TA = 25°C, OSC = GND ±0.3 nA (VIN, SET POINT and DELTA Inputs) RIN Equivalent Input Resistance fS = 1kHz (Note 5) ● 10 15 MΩ Input Voltage Range ● GND V + V PSR Power Supply Range ● 2.8 16 V IS(ON) Power Supply ON V + = 5V, VP-P ON ● 1.2 3 mA Current (Note 6) IS(OFF) Power Supply OFF V + = 5V, VP-P OFF LTC1041C ● 0.001 0.5 µA Current (Note 6) LTC1041M ● 0.001 5 µA tD Response Time (Note 7) V + = 5V 60 80 100 µs ON/OFF Output (Note 8) VOH Logical “1” Output Voltage V + = 4.75V, IOUT = –360µA ● 2.4 4.4 V VOL Logical “0” Output Voltage V + = 4.75V, IOUT = 1.6mA 0.25 0.4 V REXT External Timing Resistor Resistor Connected between V+ and OSC Pin ● 100 10,000 kΩ fS Sampling Frequency V + = 5V, TA = 25°C, 5 Hz REXT = 1M CEXT = 0.1µF
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 2:
Applies over input voltage range limit and includes gain of a device may be impaired. uncertainty. 1041fa 2
