Линейка продуктов KEEN SIDE
Datasheet LTC1998 (Analog Devices) - 7
Описание2.5µA, 1% Accurate SOT-23 Comparator and Voltage Reference for Battery Monitoring
Страниц / Страница12 / 7 — QUICK DESIGN GUIDE. How to Calculate the External Resistor Values. …
Формат / Размер файлаPDF / 139 Кб
QUICK DESIGN GUIDE. How to Calculate the External Resistor Values. Typical Application
QUICK DESIGN GUIDE How to Calculate the External Resistor Values Typical Application
16 предложений от 12 поставщиков
Микросхема Компаратор, 2.5μA, 1% Accurate SOT-23 Comparator and Voltage Reference for Battery Monitoring
LTC1998CS6#TRPBF
40 ₽
LTC1998CS6#TRPBF
74 ₽
LTC1998CS6#TRPBF
98 ₽
LTC1998CS6-TRPBF
LTC1998
Example 1: A system using a 4.2V (fully charged) Lithium- Ion battery requires a low battery threshold of 2.7V, 100mV The LTC1998 is a low battery warning indicator and is es- hysteresis and can allow up to 4.2μA maximum resistor pecially designed for monitoring the voltage of single-cell current. Lithium-Ion batteries. The LTC1998 compares its supply pin (BATT) to an accurate internal reference; if the battery RTOTAL = 1MΩ, R1 = 786k, R2 = 66k and R3 = 148k voltage falls below the programmed low battery threshold Choose standard 1% values. voltage of the LTC1998, the battery low pin (BATTLO) will change state, from high to low, to indicate a low battery R1 = 787k, R2 = 66.5k, R3 = 147k condition. The low battery threshold voltage is programmed 1.5V TO 4.2V V via the voltage threshold adjust pin (V LOGIC TH.A). A hysteresis REGULATOR adjust pin (V 0.1μF H.A) will add hysteresis to the programmed R1 1 + 1% BATT value of the low battery threshold voltage. 4 5 VH.A VLOGIC R2 LTC1998 μP
Typical Application
1% Li-Ion 3 6 V BATTLO TH.A
Table 1: Design Equations for R1, R2, R3, Figure 1
R3 GND 1% 2 Choose desired values for: 1998 F01 • V
Figure 1. Low Battery Threshold Detector with Hysteresis
BATT.Th: Low Battery Threshold Voltage • VHYST: Hysteresis Voltage • IR: Max Allowable Resistor Current Solve: 4. V 2 R = R1+ R2 + R TOTAL 3 = IR ⎛ V 5 ⎞ R1= RTOTAL • – 1 ⎝⎜ V . + V BATT Th HYST ⎠⎟ V 5 ⎞ R2 = ⎛ R • – 1 – R TOTAL 1 ⎝⎜ VBATT.Th ⎠⎟ R3 = R – R1– R TOTAL 2 1998fb 7
