Datasheet MIC7300 (Microchip) - 6
ПроизводительMicrochip
ОписаниеThe MIC7300 is a high-performance CMOS operational amplifier featuring rail-to-rail input and output with strong output drive capability
Страниц / Страница12 / 6 — Note 1. Note 2. Note 3. Note 4. Note 5. Note 6. Note 7. Note 8. Note 9. …
Формат / Размер файлаPDF / 68 Кб
Note 1. Note 2. Note 3. Note 4. Note 5. Note 6. Note 7. Note 8. Note 9. Note 10. Note 11
Note 1 Note 2 Note 3 Note 4 Note 5 Note 6 Note 7 Note 8 Note 9 Note 10 Note 11
27 предложений от 18 поставщиков
MIC7300YMM
55 ₽
SUV System
MIC7300YMM-TR
МосЧип
MIC7300YMM TR
Micrel
Контест
MIC7300YMM
Micrel
MIC7300 Micrel
Note 1.
Exceeding the absolute maximum rating may damage the device.
Note 2.
The device is not guaranteed to function outside its operating rating.
Note 3.
I/O Pin Voltage is any external voltage to which an input or output is referenced.
Note 4.
The maximum allowable power dissipation is a function of the maximum junction temperature, T ; the junction-to-ambient thermal J(max) resistance, θ ; and the ambient temperature, T . The maximum allowable power dissipation at any ambient temperature is calculated using: JA A P = (T – T ) ÷ θ . Exceeding the maximum allowable power dissipation will result in excessive die temperature. D J(max) A JA
Note 5.
Thermal resistance, θ , applies to a part soldered on a printed-circuit board. JA
Note 6.
Devices are ESD protected; however, handling precautions are recommended.
Note 7.
All limits guaranteed by testing or statistical analysis.
Note 8.
Continuous short circuit may exceed absolute maximum T under some conditions. J
Note 9.
CMRR is determined as follows: The maximum ∆V over the V range is divided by the magnitude of the V range. The measurement OS CM CM points are: V , (V – V )/2, and V . V– V+ V– V+
Note 10.
R connected to 5V. Sourcing: 5V ≤ V ≤ 10V. Sinking: 2.5V ≤ V ≤ 5V. L OUT OUT
Note 11.
Device connected as a voltage follower with a 10V step input. The value is the positive or negative slew rate, whichever is slower. MIC7300 6 June 2005
