MCP6L01/1R/1U/2/4. Note:. 1.E-0. 10 2. 1.E-03. ) 5. 1.E-04. 100µ. 1.E. s (V. itude. -05. 10µ. 1.E-06. ag lt. Mag. -07. 100n. o 3. 1.E-08. 10n. t V u 2. rrent. -09. t C
MCP6L01/1R/1U/2/4Note: Unless otherwise indicated, TA = +25°C, VDD = +5.0V, VSS = GND, VCM = VSS, VOUT = VDD/2, VL = VDD/2, RL = 10 kto VL and CL = 60 pF. 1.E-010 2m6) VIN G = +2 V/V 1.E-03(A1m) 51.E-04100µ VOUT 1.Es (Vitude-0510µen41.E-061µag lt1.EMag-07100no 31.E-0810nt V u 21.Errenttpu-091n +125°C +85°C 1.Et C-10100p +25°C 1t, Ou1.E-1110p -40°C uInpup 01.E-121pIn-1.0 -0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1 0.0-1 0.E+001.E-052.E-053.E-054.E-055.E-056.E-057.E-058.E-059.E-051.E-04Input Voltage (V)Time (10 µs/div)FIGURE 2-7: Measured Input Current vs. FIGURE 2-10: The MCP6L01/1R/1U/2/4 Input Voltage (below VSS). Show No Phase Reversal. 1200180 160) 100-30tB)(°)140A(d80-60rren120in Phase aseu60h100Ga-90t Cifier (µpp Pnplo8040o-120m-L Gain Loo60iescer a20 +125° en-150en-upe40Q C Op0-180Op20 +85°C +25°C -20-2100 40°C 1.0E.-1 1.E1+ 1.E+10 1.E+100 1.E+1k 1.E+10k 1.E10 +0k 1.E+1M 1.E10 +M0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.501000102Freq 03uen04cy (Hz) 05 06 07Power Supply Voltage (V)FIGURE 2-8: Open-Loop Gain, Phase vs. FIGURE 2-11: Quiescent Current vs. Frequency. Power Supply Voltage. 1,00030) 25A 20(m 15 ent 10rr5u -40°C 1000 +25°C it C +85°C (nV/Hz)-5 +125°C ircu -10 t C -15-20horInput Noise Voltage DensityS -2510-301.E-010.11.E+011.E+0101.E+01001.E+01k1.E+010k1.E+0100k0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.50123Frequency (Hz)45Power Supply Voltage (V)FIGURE 2-9: Input Noise Voltage Density FIGURE 2-12: Output Short Circuit Current vs. Frequency. vs. Power Supply Voltage. DS22140B-page 6  2009-2011 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuit FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 1.8V. FIGURE 2-2: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Output Voltage. FIGURE 2-4: Input Common Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Measured Input Current vs. Input Voltage (below VSS). FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L01/1R/1U/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Power Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom to Output Current vs. Output Current. FIGURE 2-14: Small Signal, Noninverting Pulse Response. FIGURE 2-15: Large Signal, Noninverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Rail-to-Rail Inputs FIGURE 4-1: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-2: Output Resistor, RISO stabilizes large capacitive loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-3: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-4: Example Guard Ring Layout. 4.7 Application Circuit FIGURE 4-5: Bessel Filter. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Microchip Advanced Part Selector (MAPS) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Product ID System Trademarks Worldwide Sales
