Клеммники KEEN SIDE
Datasheet MCP601, MCP601R, MCP602, MCP603, MCP604 (Microchip) - 10
ПроизводительMicrochip
ОписаниеMCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Страниц / Страница34 / 10 — MCP601/1R/2/3/4. Note:. 0.8. DD = 5.5V. DD = +5.0V. 0.7. G = +2. t (µA) …
Формат / Размер файлаPDF / 600 Кб
MCP601/1R/2/3/4. Note:. 0.8. DD = 5.5V. DD = +5.0V. 0.7. G = +2. t (µA) 0.6 rren. 0.5. in 0.4. put Voltages (V). t P 0.3. lec. VIN. 0.2. d Out 1. VOUT
MCP601/1R/2/3/4 Note: 0.8 DD = 5.5V DD = +5.0V 0.7 G = +2 t (µA) 0.6 rren 0.5 in 0.4 put Voltages (V) t P 0.3 lec VIN 0.2 d Out 1 VOUT
30 предложений от 18 поставщиков
MCP603T-I/CH
от 10 ₽
MCP603T-I/CH
28 ₽
ЧипСити
MCP603T-I/CH
28 ₽
LifeElectronics
MCP603T-I/CH
Unless otherwise indicated, TA = +25°C, VDD = +2.7V to +5.5V, VSS = GND, VCM = VDD/2, VOUT ≈ VDD/2, VL = VDD/2, RL = 100 kΩ to VL, CL = 50 pF and CS is tied low.
0.8 6 V V DD = 5.5V DD = +5.0V 0.7 5 G = +2 t (µA) 0.6 rren 4 0.5 Cu 3 in 0.4 put Voltages (V) t P 0.3 2 lec VIN 0.2 d Out 1 VOUT 0.1 Chip Se 0 0.0 Input an 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -1 Chip Select Voltage (V) Time (5 µs/div) FIGURE 2-31:
Chip Select Pin Input
FIGURE 2-33:
The MCP601/1R/2/3/4 Current vs. Chip Select Voltage. family of op amps shows no phase reversal under input overdrive.
3.0 1.E-0 10 2 m h V ) DD = 5.0V Amplifier On 1. A E-03 1m itc 2.5 w 1.E-0 10 4 t S ude ( e (V) 2.0 1.E-05 10µ lec g 1.E-06 lta agnit o 1.5 CS Hi to Low CS Low to Hi 1.E-0 10 7 0n ut V 1.E-08 10n 1.0 l Chip Se 1.E-09 +125°C 1n +85°C Outp 100p 0.5 1.E-10 +25°C 10p -40°C Interna Amplifier Hi-Z 1.E-11 Input Current M 0.0 1.E-12 1p 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 -1.0 -0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1 0.0 Chip Select Voltage (V) Input Voltage (V) FIGURE 2-32:
Hysteresis of Chip Select’s
FIGURE 2-34:
Measured Input Current vs. Internal Switch. Input Voltage (below VSS). DS21314G-page 10 © 2007 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics FIGURE 1-1: MCP603 Chip Select (CS) Timing Diagram. 1.1 Test Circuits FIGURE 1-2: AC and DC Test Circuit for Most Non-Inverting Gain Conditions. FIGURE 1-3: AC and DC Test Circuit for Most Inverting Gain Conditions. 2.0 Typical Performance Curves FIGURE 2-1: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-2: Slew Rate vs. Temperature. FIGURE 2-3: Gain Bandwidth Product, Phase Margin vs. Temperature. FIGURE 2-4: Quiescent Current vs. Supply Voltage. FIGURE 2-5: Quiescent Current vs. Temperature. FIGURE 2-6: Input Noise Voltage Density vs. Frequency. FIGURE 2-7: Input Offset Voltage. FIGURE 2-8: Input Offset Voltage vs. Temperature. FIGURE 2-9: Input Offset Voltage vs. Common Mode Input Voltage with VDD = 2.7V. FIGURE 2-10: Input Offset Voltage Drift. FIGURE 2-11: CMRR, PSRR vs. Temperature. FIGURE 2-12: Input Offset Voltage vs. Common Mode Input Voltage with VDD = 5.5V. FIGURE 2-13: Channel-to-Channel Separation vs. Frequency. FIGURE 2-14: Input Bias Current, Input Offset Current vs. Ambient Temperature. FIGURE 2-15: DC Open-Loop Gain vs. Load Resistance. FIGURE 2-16: CMRR, PSRR vs. Frequency. FIGURE 2-17: Input Bias Current, Input Offset Current vs. Common Mode Input Voltage. FIGURE 2-18: DC Open-Loop Gain vs. Supply Voltage. FIGURE 2-19: Gain Bandwidth Product, Phase Margin vs. Load Resistance. FIGURE 2-20: Output Voltage Headroom vs. Output Current. FIGURE 2-21: Maximum Output Voltage Swing vs. Frequency. FIGURE 2-22: DC Open-Loop Gain vs. Temperature. FIGURE 2-23: Output Voltage Headroom vs. Temperature. FIGURE 2-24: Output Short-Circuit Current vs. Supply Voltage. FIGURE 2-25: Large Signal Non-Inverting Pulse Response. FIGURE 2-26: Small Signal Non-Inverting Pulse Response. FIGURE 2-27: Chip Select Timing (MCP603). FIGURE 2-28: Large Signal Inverting Pulse Response. FIGURE 2-29: Small Signal Inverting Pulse Response. FIGURE 2-30: Quiescent Current Through VSS vs. Chip Select Voltage (MCP603). FIGURE 2-31: Chip Select Pin Input Current vs. Chip Select Voltage. FIGURE 2-32: Hysteresis of Chip Select’s Internal Switch. FIGURE 2-33: The MCP601/1R/2/3/4 family of op amps shows no phase reversal under input overdrive. FIGURE 2-34: Measured Input Current vs. Input Voltage (below VSS). 3.0 Pin Descriptions TABLE 3-1: Pin Function Table For Single Op Amps TABLE 3-2: Pin Function Table For Dual And Quad Op Amps 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Chip Select Digital Input 3.4 Power Supply Pins 4.0 Applications Information 4.1 Inputs FIGURE 4-1: Simplified Analog Input ESD Structures. FIGURE 4-2: Protecting the Analog Inputs. FIGURE 4-3: Unity Gain Buffer has a Limited VOUT Range. 4.2 Rail-to-Rail Output 4.3 MCP603 Chip Select 4.4 Capacitive Loads FIGURE 4-4: Output resistor RISO stabilizes large capacitive loads. FIGURE 4-5: Recommended RISO values for capacitive loads. 4.5 Supply Bypass 4.6 Unused Op Amps FIGURE 4-6: Unused Op Amps. 4.7 PCB Surface Leakage FIGURE 4-7: Example Guard Ring layout. 4.8 Typical Applications FIGURE 4-8: Second-Order, Low-Pass Sallen-Key Filter. FIGURE 4-9: Second-Order, Low-Pass Multiple-Feedback Filter. FIGURE 4-10: Three-Op Amp Instrumentation Amplifier. FIGURE 4-11: Two-Op Amp Instrumentation Amplifier. FIGURE 4-12: Photovoltaic Mode Detector. FIGURE 4-13: Photoconductive Mode Detector. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Mindi™ Simulatior Tool 5.4 MAPS (Microchip Advanced Part Selector) 5.5 Analog Demonstration and Evaluation Boards 5.6 Application Notes 6.0 Packaging Information 6.1 Package Marking Information
