Datasheet ADA4077-1, ADA4077-2, ADA4077-4 (Analog Devices) - 10
Описание4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Single Amplifier
Страниц / Страница27 / 10 — ADA4077-1/ADA4077-2/ADA4077-4. Data Sheet. OUT A 1. 14 OUT D. –IN A. 13 …
ВерсияE
Формат / Размер файлаPDF / 987 Кб
ADA4077-1/ADA4077-2/ADA4077-4. Data Sheet. OUT A 1. 14 OUT D. –IN A. 13 –IN D. +IN A 3. 12 +IN D. ADA4077-4. ADA4077-4 12 +IN D. TOP VIEW
ADA4077-1/ADA4077-2/ADA4077-4 Data Sheet OUT A 1 14 OUT D –IN A 13 –IN D +IN A 3 12 +IN D ADA4077-4 ADA4077-4 12 +IN D TOP VIEW
28 предложений от 11 поставщиков
ADA4077-2TRMZ-EP
762 ₽
ЧипСити
ADA4077-2TRMZ-EP
762 ₽
ADA4077-2TRMZ-EP
2 507 ₽
ADA4077-2TRMZ-EP
ADA4077-1/ADA4077-2/ADA4077-4 Data Sheet OUT A 1 14 OUT D OUT A 1 14 OUT D –IN A 13 –IN D –IN A 2 2 13 –IN D +IN A 3 12 +IN D ADA4077-4 +IN A 3 ADA4077-4 12 +IN D TOP VIEW V+ 4 TOP VIEW 11 V– V+ 4 11 V– (Not to Scale) +IN B (Not to Scale) 5 10 +IN C +IN B 5 10 +IN C –IN B 6 9 –IN C
207
–IN B 6 9 –IN C OUT B 7 8 OUT C
38- 102
OUT B 7 8 OUT C
206 238- 10 Figure 9. ADA4077-4 Pin Configuration, 14-Lead TSSOP Figure 10. ADA4077-4 Pin Configuration, 14-Lead SOIC
Table 8. ADA4077-4 Pi n Function Descriptions, 14-Lead TSSOP and 14-Lead SOIC Pin No. Mnemonic Description
1 OUT A Output Channel A. 2 −IN A Negative Input Channel A. 3 +IN A Positive Input Channel A. 4 V+ Positive Supply Voltage. 5 +IN B Positive Input Channel B. 6 −IN B Negative Input Channel B. 7 OUT B Output Channel B. 8 OUT C Output Channel C. 9 −IN C Negative Input Channel C. 10 +IN C Positive Input Channel C. 11 V− Negative Supply Voltage. 12 +IN D Positive Input Channel D. 13 −IN D Negative Input Channel D. 14 OUT D Output Channel D. Rev. E | Page 10 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V ELECTRICAL CHARACTERISTICS, ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL LOW POWER LINEARIZED RTD PROPER BOARD LAYOUT LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
